We have had our washing machine for over 10 years and it has never given us much trouble. But lately there has been an alarming amount of black flecks of dirt floating around in the water. Also it smells like sewage. We called a repair guy to come and have a look at it and when he took the machine all apart he noticed a huge build up of black clay like substance. Now we had this problem before about 7 months ago and he cleaned it for us and haven't had trouble since then. When he looked at it today he said that it was far too large of a buildup in the span of less then a year and that something else was contributing to the build up. What do you think that could be? Could it be that it's our water? Our soaps? What is your opinion?
Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
To return to the last alarm, press the START/PAUSE button.
The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
its the diecast of your inner tub cross members,nothing you can do but replace the inner tub,its just after a while the detergents start to diteriate the die cast
Hi, The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Ceck the follow instruction just to veryfy what kind of problems your dryer has.
You dont have to buy anything just check all the information that is given to you
BUY SPEED QUEEN FRONT LOADER. IT ONLY USES 13.9 GALLONS OF WATER PER WASH!!!!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Nope town water.
