Question about Defiant Brandywine Single Cylinder Stainless-Steel Entry Knob and Deadbolt
Lost key for interior house door - Defiant Brandywine Single Cylinder Stainless-Steel Entry Knob and Deadbolt
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Front doors wont unlock from interior
This one is fairly straightforward. Your car door lock has some sort of actuator located just below or just to the side of the door lock mechanism. The door lock consists of a set of geared, jaws that pop and are held open until the trigger trips and the jaws grab the striker located on the door post.
The actuator is either manual or electric. In a manual actuator, a rod reacts to the motion of the slide latch or the motion of the external key. In this case, gearing multiplies the force acting on the rod so that it can push the trigger button on the rear of the door lock housing. If the actuator is electric, the rod is activated by the actuator motor and its movement is controlled by gearing within the actuator motor housing. In any event, the actuator rod presses down upon the trigger and the door button pops open when you use the slide latch or door key.
At least, that's what is supposed to happen. In your case, I think the actuator is probably gone and must be replaced. You can actually do this job yourself if you are comfortable with tools and with removing door panels and things. The actuator is relatively easy to access, once you have removed the interior door panel. The issue is just the amount of labor that will be involved just getting to the actuator. It is the type of repair that you should actually leave to a mechanic. We've pointed out the do-it-yourself possibilities because there are many people who enjoy this work.
Sep 15, 2015 | Cars & Trucks
2005 Lancer - interior lever does not open the access door to gas cap. How do I fix it?
...Check the flat spring that kick the gas cap cover door open, two plastic holding the spring on the either side must missing, try any plastic and glue it there to not lost again and put some lube at the door hinge and the key bolt, they will pop open wide..
Aug 15, 2011 | 2002 Mitsubishi Lancer
Interior lighting will not come on when opening right sliding door. lighting comes on when opening all other doors.
the pop out button for the lights on the that door housing is probably jammed in look for it around the rim of the interior.
Feb 04, 2011 | 2006 Honda Odyssey
Problem with dual zone heating only one side i check control thermost botton is ok
Sounds like the blend door actuator. It separates the driver and passenger side from getting air on the AZC system. Here are some instructions on replacing it:
The passenger side blend door actuator is used on all models equipped with Automatic Zone Control (AZC). This actuator is located on the front of the HVAC housing to the right of the floor panel transmission tunnel and cannot be removed from the passenger compartment without instrument panel or HVAC housing removal.
NOTE: This procedure is for AZC Systems (Passenger side only).
  1. Disconnect and isolate the battery negative cable.
  2. Remove the glove box door. See: Body and Frame\Interior Moulding / Trim
  3. Remove the lower I/P glove box door surround panel.
  4. Remove the dash assembly. See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
  5. Remove the HVAC assembly. See: Housing Assembly HVAC\Service and Repair
  6. Unplug the wire harness connector from the blend door actuator.
  7. Remove the 2 screws that secure the blend door actuator to the HVAC housing.
  8. Remove the blend door actuator from the HVAC housing.
INSTALLATION - AZC (Passenger side only)
  1. In stall the blend door actuator on the HVAC housing and tighten the two mounting screws to 2.2 Nm (20 in. lbs.).
  2. Plug in the wire harness connector to the blend door actuator.
  3. In stall the HVAC unit into the vehicle. See: Housing Assembly HVAC\Service and Repair
  4. Install the instrument panel assembly into the vehicle. See: Body and Frame\Interior Moulding / Trim\Dashboard / Instrument Panel\Service and Repair\Instrument Panel Assembly
  5. Evacuate the HVAC system.
  6. Recharge the HVAC system.
  7. Connect and the battery negative cable.
Hope it helps! If you need more, just send me an email at familyguy77351 at yah I wil be glad to finish helping you with more detail.
Dec 12, 2010 | 2000 Jeep Grand Cherokee
In my 99 beelte the rear hatch will not open. (not with the button on the door or with the key) When I bought the car about 3 weeks ago I was only given the "Valet Key". is there a "valet...
Welcome to FIxYa.com
the fuel door and trunk release should be in one panel on door.
Too there is a relay that may have gone bad.
Check relay and all fuses
Check fuse with test light
550604 tech #
Jun. 5, 2006
2O1l907l
Condition
Customer States Rear Decklid. Hard to Close
Customer states rear deck lid not closing properly.
Technical Background
Due to the stiffness of the original lock dampening rubber, the rear deck lid may be
Difficult hard to close.
Production Solution
A new lock dampening rubber was incorporated into production during calendar week
(CW) 4405. beginning ith VIN: IC_6M407025.
Service
Install improved lock dampening rubber Part No. lCO 827 589 B:
Open rear deck lid.
A Remove rear decked trim panel (see Repair Manual, Body Interior, Group 70- Interior
Remove Lock housing cover.
Tip:
To remove lock housing cover, gently pry between the locking pawl and cover guides
while pulling down on cover. Underside of cover shown for case of location identification.
A Remove the lock dampening rubber by pulling downward out of lock housing.
Install new rear lock dampening rubber Part No. lCO 827 589 B.
Tip:
Ensure proper engagement of lock dampening rubber retaining tab into the lock housing
and is seated on the guide slots.
A Install lock housing cover.
A Install rear deck lid trim panel (see Repair Manual, Body Interior, Group 70- Interior
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 18, 2010 | 1999 Volkswagen Beetle
Microwave won't come out of start up mode. Clock flashing 00:00 and interior light on. Just moved house, owned micro for 3 years, lost manual in move. Please help.
could be a broken door hook; defective door microswitch or the microswitch bracket itself. the door just may need adjustment; as many people lift microvave by the bottom of the door; which is a no-no.
Aug 24, 2010 | Sharp R-654 Convection/Microwave Oven
Radio, Key auto door lock/opener, interior lights not working.
Most likely is a fuse. There is a fuse box at the end of the right side of the dash. Open front passenger door and there is a cover that says fuses on the end of dash. There is also a fuse box located under the hood at the right front of engine compartment. It should have a cover with a round knob in the middle of it .Unscrew the knob to remove cover.
Feb 18, 2009 | 2003 Chevrolet Venture Passanger
Defiant Brandywine Single Cylinder Stainless-Steel Entry Knob and Deadbolt Logo
Top Defiant Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Defiant Lock and Locksmithing Expert? Answer questions, earn points and help others
