Question about AEG 18 in. Favorit 44630W Slim-Line Free-standing Dishwasher
AEG favorit 44630, circulation pump not working. How do I remove it to see if there is a blockage?
  • 1462 Answers
SOURCE: Remove bottom front panel AEG 6081
before you take the pump out, if drain hose goes into a spigot on the sink trap, take drain hose off and check hose and spigot are not blocked. this is very common.
can't remember anything special about the screws - used to be philips head but may have changed to multi-spline.the top ones are indeed obscured by the door panel but you can normally get to them with a stubby screwdriver or take the outer door panel off - just a few screws
Posted on Sep 06, 2008
TheMazz
  • 78 Answers
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 17, 2009
Testimonial: "very quick, thankyou"
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG Favorite Compact 525 Dishwasher. The pump runs continuously
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
joe_lishman
  • 192 Answers
SOURCE: aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
Dishwasher no circulation
Hi
Now you said it won't circulate when it gets to this point can you put your hand on unit and feel it vibrating like the motor is trying to run if so you have something in sump area jamming it. Remove foreign object. If it does not vibrate then you may have a bad motor or main board. To test if you know electronics look at board and find connection for motor and check if you get 120V if so then either bad motor or stuck. Good Luck
Mar 06, 2014 | AEG Dishwashers
What does problem .20 mean?
E20 this relates normally to a blockage in the drain pump or something blocking the drain side of the dishwasher.
Hope this helps.
Sep 20, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit 60820 sensorlogic .30 code water problem
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
Jun 06, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Sep 06, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG 18 in. Favorit 44630W Slim-Line Free-standing Dishwasher Logo
139 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
