Question about clubdjpro ClubDJ ProVJ
Code ClubDJ ProVJ 5 1 5 5 - clubdjpro ClubDJ ProVJ
How can i drill a hole into my keepsafe wall safe to open it?
Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
Activation serial number
Club dj Pro vj 5.1.5.8 activation key
Feb 23, 2014 | clubdjpro ClubDJ ProVJ
20 (combination of letters upper and lower cases and numbers)
Jan 27, 2014 | clubdjpro ClubDJ ProVJ
Provj 5 Activate key / name & code
hi my mame asif i wont
Sep 01, 2011 | Computers & Internet
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
I would like to be able to lock the keypad with a code
If you will be the only user you can Changing the Lock Code and no body can enter in the system once you make the change.So don,t share the code with anybody.
Your SX5T is preconfigured with a lock code for use in entering Configuration Mode and to use
with the Call Barring feature. The default lock code is the last four digits of the phone number.
(If no number is programmed, the default is 0000).
You may use Configuration Mode to change your lock code to any 4-digit number.
To change the Lock Code:
• From Configuration Mode, press: # * 1 4 3 *
For example, to change the default lock code from 0000 to 5555, press
# * 1 4 3 * 0 0 0 0 * 5 5 5 5 * 5 5 5 5 #
Dec 01, 2010 | Verizon Communications Telular CDMA Dual...
I BOUGHT A 95 LINCOLN CONTININTAL USED AND I DO NOT KNOW WHAT THE CODE IS ON THE DOOR KEYPAD AND I WOULD LIKE TO RESET THE CODE HOW DO I CHANGE IT WITHOUT KNOWING WHAT THE OLD CODE WAS.
The factoty code is found in the trunk on the right side lift support. The factory code can never be deleted. To reset and delete any added codes, key in the 5 digit factory code. Within 5 seconds press the 1/2 button. Within 5 seconds again press the 1/2 button again. All previously added codes are delete. To add your own code, key in the 5 digit factory code. Within 5 seconds press te 1/2 button. Within 5 seconds again enter your personal 5 digit code. Note that when you complete these steps, the doors will lock then unlock meaning that the command to add or delete a code is complete. You can add 5 different codes in the memory, but when you complete the delete command, it deletes all added codes but never the factory code.
Feb 23, 2010 | 1995 Lincoln Continental
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Keyless entry keypad
retrieving is probably not an option however if you know the factory code , you can add 1 personal code which in turn would erase any other personal codes . your owners manual should back this statement up . follow these steps >>>>>
The keyless entry touch pad can use two codes. The factory code and one
personal code .
To program your own personal code, select a 5 digit code that doesn't use 5 digits in
sequence or the same button 5 times.
Enter your factory code
Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
pressing each digit within 5 seconds of the previous digit.
You can now use either code to operate the keypad
Jan 12, 2009 | 2003 Ford Expedition
Computers & Internet Logo
20 people viewed this question
Top clubdjpro Computers & Internet Experts
David Payne
David Payne
Are you a clubdjpro Computer and Internet Expert? Answer questions, earn points and help others
