Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John deere rx75 adjust belt tension - John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Dec 24, 2016
rwvanlue
  • 486 Answers
SOURCE: adjusting belts & veriato
Belts on the variator system are spring loaded, they 'self-adjust'. If they are not working correctly, they are worn & the center pulley of the variator can be worn so it 'cocks' sideways as the belts work.
*the only adjustment is the sicronizing of the variator to the foot pedal. This only effects the lever in the full back position. If it is out of adjustment, the tractor will stop in the full back position.
Posted on Nov 23, 2009
  • 146 Answers
SOURCE: I'm attempting to replace the primary belt on a
There is an idler pulley that puts tension on the belt. You unhook the spring from the idler arm, put the new belt on (it will be loose, not tight) then hook the spring back onto the idler by pulling hard on the spring with a pair of visegrip or channellock pliers. Here's a parts diagram. Good luck! Please rate my solution if helpful, thanks.
Posted on Aug 03, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a John Deere
I hear that on the service manual and the springs. Take a look at these decks if you talking about a deck belt and find yours. Then look for the spring routing visually.
http://opebycrigby.tripod.com/decks/jddeck.html
If you need drive belt info look here:
http://opebycrigby.tripod.com/drive/jddrive.html
I would like to know if this was enough info for you so that you were able to re-connect the spring.
Thanks for choosing FixYa,
Kelly
Posted on Jul 01, 2011
  • 25 Answers
SOURCE: need maintanance help for RX75 lawnmower, oil change, blade sharpenening
Richard,
Here is a website that might help you...
http://www.deere.com/wps/dcom/en_US/services_and_support/product_support/order_manuals_and_parts_catalogs/order_manuals_and_parts_catalogs.page?
There are other links for manuals in on this site too if you have not already tried.
Posted on May 29, 2012
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
My rx75 runs well but will not engage the deck is it electronic?
The mower deck is 100% manually controlled with the yellow control handle. The linkage may be out of adjustment a lot, especially if new belts are now broken in. When engaged, the blade drive belt should be quite taunt,but not like a banjo string. Adjustment is easy and can be found on the operators manual.
Jun 18, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a john deere rx75 and having a problem with mower belt coming off and breaking help it never did this before
The belt most likely is ready to be replaced, the only other adjustment you could make is to adjust the tension arm and move it closer to the belt to add tension when the clutch is engaged.
Apr 21, 2010 | American Standard Garden
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
1,922 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
