Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John deere rx75 - how to tighten or adjust belt tension
Belt comes off often - new belt - new spring - how to tighten or adjust the belt tension
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a John Deere
I hear that on the service manual and the springs. Take a look at these decks if you talking about a deck belt and find yours. Then look for the spring routing visually.
http://opebycrigby.tripod.com/decks/jddeck.html
If you need drive belt info look here:
http://opebycrigby.tripod.com/drive/jddrive.html
I would like to know if this was enough info for you so that you were able to re-connect the spring.
Thanks for choosing FixYa,
Kelly
Posted on Jul 01, 2011
  • 25 Answers
SOURCE: need maintanance help for RX75 lawnmower, oil change, blade sharpenening
Richard,
Here is a website that might help you...
http://www.deere.com/wps/dcom/en_US/services_and_support/product_support/order_manuals_and_parts_catalogs/order_manuals_and_parts_catalogs.page?
There are other links for manuals in on this site too if you have not already tried.
Posted on May 29, 2012
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
How do i tighten the timing belt tension on a 1999 dodge stratus
The belt tensioner is not adjustable. To loosen a tensioner you would swivel the belt tensioner away from the belt with a long flex wrench or ratchet and to tighten the belt you would let the spring in the tensioner move the swivel back into the tight position. An internal spring tightens the tensioner pulley against the belt. You will need to get a smaller belt or replace the tensioner if the belt is "too loose" after you swivel it back into the tight position against the belt and release pressure.
Oct 19, 2012 | 1999 Dodge Stratus
How do i remove the timing belt tensioner without the proper tool?
TO LOOSEN THE BELT TENSIONER PULLEY ASSEMBLY, THEN POSITION A CAMSHAFT BELT ADJUSTER TOOL T74P-6254-A OR EQUIVALENT ON THE TENSION SPRING ROLL PIN AND RETRACT THE BELT TENSIONER AWAY FROM THE TIMING BELT.TIGHTEN THE ADJUSTMENT BOLT TO LOCK THE TENSIONER IN THE RETRACTED POSITION. INSTALL NEW TIMING OVER THE CRANKSHAFT SPROCKET AND THEN COUNTERCLOCKWISE OVER THE AUXILIARY AND CAMSHAFT SPROCKETS MAKING SURE THE LUGS ON THE BELT PROPERLY ENGAGE THE SPROCKET TEETH ON THE PULLEYS. BECAREFUL NOT TO ROTATE THE PULLEYS WHEN INSTALLING THE BELT.RELEASE THE TIMING BELT TENSIONER PULLEY ALLOWING THE TENSIONER TO TAKE UP THE SLACK. IF THE SPRING DOES NOT HAVE ENOUGH TENSION TO MOVE THE ROLLER AGAINST THE BELT.AND BELT HANGS LOOSE, IT MIGHT BE NECESSARY TO MANUALLY PUSH THE ROLLER AGAINST THE BELT AND TIGHTEN THE BOLT. YOU WILL NEED BELT TENSIONER TOOL OR EQUIVALENT.YOU CAN GO ON LINE INTERNET FIND THE BELT TENSIONER TOOL.SHOULD COST TOO MUCH.YOU CAN SEE IF AUTO ZONE HAS ONE TO RENT YOU.
Mar 16, 2011 | 1998 Mazda Pickup
Timing belt
TIMING BELT & SPROCKETS R & I
NOTE: Some procedures may differ slightly due to engine
construction.
Removal
1) Remove all necessary air ducts. Position No. 4 piston at
TDC of compression stroke. Align timing marks. See Fig. 2. Remove fan
and fan shroud. Remove belts. If necessary, remove radiator and
splashguard.
2) Prevent engine from rotating and remove crankshaft timing
pulley retaining bolt. Remove upper and lower timing belt covers.
Remove spring from tension pulley. Loosen adjusting bolt and move
pulley toward water pump. Remove timing belt.
CAUTION: Ensure pistons are at TDC when rotating camshaft or damage
may result.
Inspection
1) Handle timing belt carefully. Avoid twisting or kinking
belt. Do not allow belt to become contaminated by water, oil, dirt or
other contaminates. Inspect belt for cracks or damage. If necessary,
replace.
2) Measure tension pulley spring length and force. Spring
length should not exceed 2.76" (70.2 mm) and spring force should not
be less than 197-347 lbs. (27-48 kg).
3) Replace tension pulley spring if not within specification.
Installation
1) Pull tensioner fully toward water pump side and
temporarily tighten retaining bolt. Ensure No. 4 cylinder is at TDC on
compression stroke by rotating crankshaft until keyway aligns with
mark on front crankshaft seal housing (12 o'clock). Rotate camshaft
until timing mark on cam gear (arrow) aligns with mark on upper
camshaft cover (notch). See Fig. 2.
NOTE: When timing marks are aligned as stated above, No. 4 piston
is at TDC on compression stroke.
2) Position timing belt over crankshaft sprocket, oil pump
sprocket, camshaft sprocket and tensioner in that order. Ensure belt
is positioned in sequence given and without slack between sprockets.
Loosen tension sprocket adjusting bolt allowing spring tension to
tighten belt. Tighten adjusting bolt temporarily.
3) Temporarily install crankshaft pulley bolt and rotate
crankshaft 2 complete revolutions in opposite direction of engine
rotation, until marks on crankshaft and front oil seal retainer are
aligned again. See Fig. 2. Loosen tensioner lock bolt, allowing
tesioner spring to fully adjust tension. Tighten tensioner lock bolt.
4) Install timing belt covers. To complete installation,
reverse removal procedures. Tighten all bolts to specification. See
TORQUE SPECIFICATIONS table at end of this article.
Fig. 2: 2.3L & 2.6L Timing Alignment Marks
Courtesy of Isuzu Motor Co
Dec 13, 2010 | 1989 Isuzu Pickup 2WD
Where is the tension pully on a 1993 ford taurus 3.0 motor
there is no spring tensioner on some of the 3.0 engines. See instructions below. I will paste a pic on the version that DOES have a tensioner at the bottom of this post.
3.0L Engine-Except SHO
ALTERNATOR BELT WITHOUT AUTOMATIC TENSIONER
  1. Loosen the adjusting arm and pivot bolts.
  2. Turn the alternator belt adjusting screw counterclockwise until the old belt can be removed.
  3. Remove the belt.
To install:
  1. Install the new belt over the pulleys. Check that all the V-grooves make proper contact with the pulleys.
  2. Adjust the belt tension, then tighten the adjusting arm and pivot bolts.
3.0L SHO Engine
ALTERNATOR BELT
See Figure 2
  1. Loosen the nut in the center of the idler pulley.
  2. Loosen the idler adjusting screw until the old belt can be removed, then remove the belt.
To install:
  1. Install the new belt over the pulleys in proper contact with the pulleys.
  2. Adjust the new belt to specifications as follows: Turn the idler pulley nut to the right to tighten the belt to a specification of 220-265 lbs. (980-1180 N). Torque the idler pulley nut to 25-37 ft. lbs. (34-50 Nm).
POWER STEERING AND AIR CONDITIONING BELT
See Figure 2
  1. Remove the alternator belt.
  2. Loosen the nut on the tensioner pulley.
  3. Turn the belt adjusting screw on the tensioner counterclockwise until the belt can be removed, then remove the belt.
To install:
  1. Position the new belt over the proper pulleys, making sure the V-grooves are properly seated.
  2. Install the alternator belt.
  3. Adjust the power steering and air conditioning belt to a specification of 154-198 lbs. (690-980 N) with a belt tension gauge.
  4. Adjust the alternator belt.
3.0L Engine (Except SHO) and 3.8L Engine
VEHICLES THROUGH 1993 WITH AUTOMATIC TENSIONER
See Figures 4 and 5
  1. Insert a 1 / 2 in. breaker bar into the square hole in the tensioner.
On the 3.8L engine, the tensioner has a1/2in. square hole cast into the rear of the tension arm directly behind the pulley. On the 3.0L engine, the1/2in. square hole is cast into the spring housing on the front of the tensioner.
  1. Rotate the tensioner clockwise and remove the belt.
Fig. Fig. 5: 3.8L belt schematic-1993 shown
To install:
  1. Install the drive belt over all the pulleys, except for the alternator pulley on the 3.0L engine for vehicles through 1992, or the idler pulley for 1993 3.0L vehicles.
  2. Rotate tensioner counterclockwise and install the belt over the alternator pulley. Make sure that all the V-grooves make proper contact with the pulleys.
  3. On the 3.0L engine, install the alternator belt for vehicles through 1992.
  4. For 1993 3.0L vehicles, install the drive belt over the idler pulley.
Oct 01, 2010 | 1993 Ford Taurus
Changing the timing belt on a Hundai
  1. Remove all necessary components for access to the timing belt cover, then remove the cover.
  2. Rotate the crankshaft clockwise and align the timing marks so No. 1 piston will be at Top Dead Center (TDC) of the compression stroke.
  3. Loosen the tensioning bolt and the pivot bolt on the timing belt tensioner. Move the tensioner as far as it will go toward the water pump. Tighten the adjusting bolt.
  4. Mark the timing belt with an arrow showing direction of rotation.
  5. Remove the timing belt.
  6. If defective, remove the timing belt tensioner.
  7. Align the timing marks of the camshaft sprocket and check that the crankshaft timing marks are still in alignment.
  8. If removed, install the timing belt tensioner, spring and spacer with the bottom end of the spring free. Tighten the adjusting bolt slightly with the tensioner moved as far as possible away from the water pump.
  9. Install the free end of the spring into the locating tang on the front case.
  10. Position the timing belt over the crankshaft sprocket, then over the camshaft sprocket. Slip the back of the belt over the tensioner wheel.
  11. Turn the camshaft sprocket in the opposite of its normal direction of rotation until the straight side of the belt is tight and be sure the timing marks align.
    NOTE If the timing marks are not properly aligned, shift the belt 1 tooth at a time in the appropriate direction until they are aligned.
  12. Loosen the tensioner mounting bolts so the tensioner works, without the interference of any friction, under spring pressure. Be sure the belt follows the curve of the camshaft pulley so the teeth are engaged all the way around. Correct the path of the belt, if necessary.
  13. Tighten the tensioner adjusting bolt, then the tensioner pivot bolt to 15-18 ft. lbs. (20-26 Nm).
    NOTE Bolts must be tightened in the stated order or tension won't be correct.
  14. Turn the crankshaft 1 turn clockwise until timing marks again align to seat the belt.
  15. Loosen both tensioner attaching bolts and let the tensioner position itself under spring tension. Retighten the bolts.
  16. Check belt tension by putting a finger on the water pump side of the tensioner wheel and pull the belt toward the water pump. The belt should move toward the pump until the teeth are approximately 1 / 2 of the way across the head of the tensioner adjusting bolt. Re-tension the belt, if necessary.
  17. Install the timing belt covers and all other related components.
Feb 09, 2010 | Hyundai Motor 2004 Sonata
Drive belt adjustment
most belts are tightened by an idler pulley, which is either controlled by
1) the operator moving or sqeeqing a lever (this type of system may have a cable adjustment)
2) and/or a tensioner spring tightened idler pulley
no adjustment is required
3) if the belt is still too loose, and new belt may be required
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Troy-Bilt Garden
Husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
Jun 20, 2009 | Husqvarna Zero Turn Mower Z5426
Drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Mar 29, 2009 | Garden
What tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the...
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
Jan 21, 2009 | Chrysler Concorde Cars & Trucks
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
103 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
