Question about Frigidare PLGC36S9EC 36 in. Portable Gas Cooktop
Ice maker line freezes
Can thaw out the waterlines to the ice maker only to refreeze in the next week.is there a fix to keep water supply lines from freezing?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
You could try fitting a non return valve close to the ice maker.
Posted on Jul 10, 2014
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
G E Select ice maker has stopped making ice
First, check the filter and make sure it isn't clogged. Second, check the water line and more importantly, the valve that feeds the water to the fridge. It should be 1/4'' line and usually has a saddle valve installed off another larger cold water line. Saddle valves have a tendency to rust and clog. these are simple fixes, generally. IF all these check out OK, Check the water valve inside of the fridge, where water line comes in..Hope this solves your problem.Good luck DW
May 11, 2014 | GE Ribbon Module for Select-Top Modular...
I have a gas odour below the Miele Gas Hob.
Call your gas company again. What you don't want is an explosion! PDQ!!!
Nov 27, 2012 | Cooktops
Does not make ice
there a lot of could be's / so look for a frozen inlet tube wher it dumps into tray / a bad water valve./ freezer tempt must be below 15 deg. for ice maker to cycle . and most common the ice maker itself may be bad . mm . if more info is needed and thes didn't help nee model & brand .. mm
Dec 12, 2009 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Aug 09, 2008 | GE Cooktops
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
Frigidare PLGC36S9EC 36 in. Portable Gas Cooktop Logo
75 people viewed this question
Top Frigidare Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Frigidare Cooktop Expert? Answer questions, earn points and help others
