Question about Watches
Ajanta Quartz odc 160 wall clock but have misplaced the operating instructions. Can someone please help me with the setting instructions.
3 Suggested Answers
gemineye61
  • 831 Answers
SOURCE: i have a quartz
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Posted on Aug 15, 2010
    • 16 Answers
    SOURCE: Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Posted on Nov 03, 2010
    HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH. ALARM KEEPS BEEPING EVERY DAY AND I DONT WANT THAT.
    Ask the maker via the Contact page. Looks cheap and nasty!
    http://ajantaworld.com/index.php/products/time-products/picture-clock/digital/lcd.html
    Sep 28, 2015 | Watches
    I need instructions for Acctim FELDBURG Cuckoo Wall Clock
    Hi, not much info on this clock specifically. This might help though :)
    Instructions Quartz Cuckoo Clocks
    Jan 31, 2015 | Watches
    How to adjust the correct time of ajanta quartz ODC-120
    move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
    Oct 14, 2013 | Watches
    I own a Ajanta Quartz odc 170 wall clock but have misplaced the operating instructions. Can someone please help me with the setting instructions. Many thanks. Joshua
    There is a sliding button on the back side to the right of inner frame. The slider has "Normal -> Time -> AL SNZ -> CountDown->Timer" marked on it.
    You need to move that button to time basically to the right side and then user up and down buttons to adjust the time.
    Hope this helps.
    -- Anant
    Jan 29, 2013 | Watches
    Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
    Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
    Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
    If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
    Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
    Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
    I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
  • Aug 15, 2010 | Watches
    John
    Apr 21, 2010 | Watches
    Watches Logo
    79 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
