Question about Konica Minolta Office Equipment & Supplies
Not rotating recycling unit bh600 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
What is a recycling Unit never hear of that unit on Bizhub 600.
Posted on Jan 10, 2016
C-3402 KONICA MINOLTA BH600
did you changed the fusing unit? if not, try to change it (connection problem with electrical card). or also, it could be an electrical problem. Stop the machine, push the Utility/counter button when starting the machine (with the button 0/1 within the door). a screen will appear with (trouble reset) tick on it, it will says ok. try to stop and restart the copier.
Nov 16, 2013 | Konica Minolta bizhub Office Equipment &...
Error code F-26-1
Is the devoper unit turning? Wipe the mag roller clean & power up, is the roller covered again by dev/toner, if not, it's the dev motor that's failed. Have you checked the toner recycle unit at the back? These get blocked , so no toner gets into the dev unit, is the m/c noisy, check the drum recycle unit isn't blocked.....is the toner bottle turning....
Oct 28, 2013 | Office Equipment & Supplies
My company have 2 unit photocopier machine model TOSHIBA e-studio 600...now this 2 unit have a same problem (display CD30)..what is the meaning of CD30...could u please help me...
CD30 shows that the waste toner on the recycle unit is full. U need to dispose it. Open the front cover, take out toner drive, take out the 2 covers, and u will see the recycle unit.
May 25, 2011 | Toshiba E-STUDIO 850 Copier
Does this Canon printer have a chip that needs to be removed before the fax machine is discarded?
all fax/printers/copiers will have a printed circuit (PC) board which may contain hazardous materials. These are usually not accessible to users without taking the entire unit apart. In addition, there may be other sources of lead, mercury, and other hazardous materials in other parts (fusers, toners, etc.) as well. I would recommend taking this unit to a recycling center vs. throwing it in the trash. They will safely remove any hazardous parts and recycle the rest of the unit.
I found a site with many listings for recycling, many of which are free of charge.
http://www.ecyclingcentral.com/
Hope this helps.
Mar 02, 2011 | Canon LaserClass 2060P Plain Paper Fax
CF60
[CF60] Recycle toner transport area lock
Check to make sure that the recycled toner auger is able to turn. This is located on the front side of your process unit and takes used toner and dumps it back in the developer unit. If not check to make sure all of your gears are not stripped.
Oct 01, 2010 | Toshiba e-Studio 232 Black and White...
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
missing or incorrectly
installed. Ensure that the
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
I need a repair manual for a Blind Hemmer model BH600. The timing seems off and the chain stitch won't work. The owners manual has the problem solving page in every language but English. Thanks
Had the same problem, and after much anguish and coming close to throwing the thing out on the street, resorted to taking it to a competent sewing machine repair person. Seemed it was a combination of upper tension, and the lower arm for threading the chain. Cost me $50, but the machine works like a dream now!
Mar 14, 2010 | Sewing Machines
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
I have 2 problems with my toshiba 550. service code CD3 and SPC
The CD3 error is related to the recycled toner unit. the recycled toner is backed up/clogged.
Toshiba made a parts change to the design of the recycle toner unit by replacing a bushing with a roller bearing and a seal. depending on how old your copier is it may or may not have this modification. The copier firmware/software also needs to be updated to the most current version and along with that there are a few internal settings that need to be adjusted.
If you are unable to do any of the above then try this - (it will get rid of the problem short term) clean/vacuum out the toner recycle unit.
If you open the front cover of the copier you will a white plastic pipe sitting at about a 45 degree angle (below the toner cartridge) - this is the pipe that leads to the recycle unit on the right. The whole unit needs to be removed and taken apart and cleaned, inside and out, including the pipe.
The SPC code is related to this issue and should also go away.
Hope this helps.
Mar 31, 2009 | Toshiba E-STUDIO 550 Copier
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
