Question about Sharp LC Televison & Video
No video upon start - LC Sharp Televison & Video
I have a gateway nv79u and it wont stay on for more than 30 mins. It keeps shutting off with error code 41 kernal-power.
Hi Michael,
Kernel Power - Error Code 41 often times caused by conflicting drivers. If you are trying to play a game or watching videos then the computer suddenly turns off, you must first check the following:
1. Open Device Manager (click Start > type Device Manager) and go to Sound, Video, and Game Controllers and see you have two audio drivers installed and disable one at a time and see if it fixes the issue.
2. Boot into Safe mode (press F8 continuously upon boot up) and see if the computer still shuts down there. (If it doesn't try disabling start-up items using this guide
3. If you're pop-up error messages like "System services cannot be started" upon boot-up, you're operating system is corrupted and must be restored to default settings. (you need to press F11 upon boot up - remember to backup your important files)
3. If Step 2 above is true, check if the computer is overheating. If it does, the computer needs to be serviced. Contact gateway support at 1-800-846-2000.
Cheers.
Sep 01, 2011 | Gateway NV7915u Notebook
Hi No video at all. I have power and can hear the HDD spinning and that is it. The screen is completely black. In fact, there is also no sound. Just a black screen. Any idea's?
You did not mention the Motherboard type.
Check the bios setup upon starting( those words when you start up your comp. ), if that appears press F2 or Del( depends on Motherboard ). Set it to "default" and save and restart.
A long press of F8 upon starting will show the OS.
If no words shows up, just light blinking on upper left hand corner, the problem will be hardware( parts of the computer ), if you have no experience on repairing and testing the hardware better brig it to your nearest technician. because it will be a trial and error of parts... such as the PSU, memory, processor, video card, monitor and HD.. Just to point which part broke down.
Hope that helps you out!
thanks for asking FixYa!
Aug 15, 2011 | Computers & Internet
I cannot access during downloading godswar online in facebook
Try installing Real Player (free) at downloads.com. When video content is played it will prompt you if you want to download (save the video). Note, some videos are "protected" against downloading. There are other software programs at download.com and on Firefox add-ons which might also help. Real Player will inform you upon starting to download if the video is not down-loadable.
Mar 06, 2011 | Online Videos Download
Engine stutters upon start up (Hot or Cold Ambient temp)
please go to the following website i specify to tackle your problem which contains a procedure with video and photo assistance. i wont be able to post such a long solution so i am directing you to the following website.
www.2carpros.com/first_things/engine_stalls.htm
Aug 03, 2009 | 2000 Toyota Corolla
The video tends to be cut off halfway.
your internet connection is the problem....
May 11, 2009 | YouTube Videos
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
