Question about Lexar Electronics - Others
Lexar sd card error, it is a 16gb Lexar sd card. When I put the card in my camera it says "card error-card is locked. Need to know how to fix this card.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lexar Master
  • 102,366 Answers
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 20, 2014
SOURCE: how to unlock my 1GB lexar camera memory card
Look at your card to see if you may have broken the small tab off from the locked side. I noticed that my card looks different and I may have broken it off not knowing.
Posted on Mar 01, 2009
  • 7 Answers
SOURCE: Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Posted on Mar 23, 2009
  • 256 Answers
SOURCE: my memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
Posted on May 28, 2009
  • 112 Answers
SOURCE: My computer can read the Lexar 1GB SD. But Kodak wont.
I suggest formatting the card using the utility in the camera. This will delete any data that is currently on the card.
Posted on Sep 16, 2009
Schmead10
  • 650 Answers
SOURCE: put new lexar sdhc 4GB memory card in my canon
see if their might be some photos or file saved that you may have edited on the card maybe Microsoft visual studio's photo shop save to hard drive. delete with photo software and format put in camera format again. if it works with computer and not with the camera not compatible try another card
Posted on Jul 04, 2010
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
Aug 01, 2012 | Pentax Optio 450 Digital Camera
Is lexar 16GB SD card compatible with olympus evolt e500
It should work in the Olympus. Insert the SD card then power up the camera and go to the Menu setting and format the SD memory card.
May 27, 2012 | Olympus EVOLT E-500 Digital Camera
My JVC-GRHD1
This camcorder will use SD cards. However it will not use SDHC cards such as your 16GB Lexar card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 19, 2012 | JVC GR-HD1 Mini DV Digital Camcorder
If my JVC-GRHD1 won't record on an SD card which type of card do I need?
It says my card is locked, how do i find the password and fix it?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jan 19, 2011 | Lexar Professional High-Speed 2GB Secure...
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Aug 31, 2009 | Moultrie MFH-DGS-200 Digital Camera
Unprotect memory card
To set the memory card in unprotected mode, you have to do the following.
On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
This unprotects the card. You should now be able to take pictures and videos.
If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
~Lexar SD card
~1 Panasonic SD card
~2 Panasonic SD card
~Sandisk SD card
Jul 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Electronics - Others Logo
128 people viewed this question
Top Lexar Electronics - Others Experts
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
