Question about Teac Audio Players & Recorders
Using Teac LEV2494FHD as PC Monitor
I want to connect my PC to my LEV2494FHD TV via HDMI but the image is fuzzy. Is this just a native resolution problem or something more complex regarding the signal itself?
tech48
  • 624 Answers
SOURCE: Lightning Damage?
First let me say I am sorry to hear this has happened to you.
I have been repairing these type of units since they came out on the market.
Yes there is a small ray of hope, but it doesn't sound good.
Unplug all of your equipment for about 3 hours and then plug it all back in again. I would not expect this to fix the problem, but it is always worth trying. It will reset all of your equipment and you can rule out the possibility that resetting anything will work.
Then make sure all the settings are right for the inputs they are connected to. When using these type of receivers, you must assign the inputs to the proper digital device you are using, in this case the HDMI.
Because you heard the loud pop in the speakers, you do have a problem in the receiver. Most likely it is in the digital board that the HDMI plugs into. These are very costly boards and in many brands they do not offer them as a replacement part. They are extremely difficult to troubleshoot and repair at board level also.
Even though this may sound bleak, if you have home-owners or renters insurance it should be covered. I have repaired and replaced many peoples audio/video systems covered by the home-owners or renters insurance for this exact reason. Lightning damage is a very common problem. Even most of the equipment protected by a surge protector can still be damaged.
But it is still a good idea to have the best surge protector you can get.
Contact your agent and find out about your coverage, and it is likely that you will be told to have all of the equipment in your home checked and then taken in to a repair center.
Once again I am sorry you have such a difficult problem.
If I can be of any further help, don't hesitate to ask.
Posted on Jun 26, 2008
  • 151 Answers
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
SOURCE: Native Reolution?
first, check outlet, make it sure that power is on the appropriate voltage. then your UPS and voltage regulator also. try to check all button switch and your video card
Posted on Sep 30, 2008
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
Posted on Jan 04, 2009
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
Jan 01, 2014 | Acer AL1917W LCD Monitor
Flatron m2362d
Hello
Researching your monitor specifications, it has a native resolution of 1920x1080 so the setting you are running should work.
Have you tried the other HDMI port on the monitor? It has to inputs and it is possible that the current port is causing the reported issue.
Another option is to get a DVI to HDMI adapter OR use a DVI cable with your graphics card to see if that corrects the issue. It is possible that the HDMI inputs are going bad and using a different input could resolve the issue. Both DVI and HDMI are digital inputs so you should not see any quality differences between the two connections.
The final check would be to connect your PC to another HDMI enabled screen (another monitor or TV) and see if the resetting continues on a different screen. If the problem occurs on a different display, you will likely have to download and install the latest video drivers for your card.
Hope this helps.
Nov 09, 2013 | Computers & Internet
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
PC to TV HDMI poor text quality
You get best picture on any LCD monitor or TV when the PC video resolution is set to the native resolution of the monitor or TV. You need to look at your user manual to find out what the native resolution is in PC mode.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 10, 2010 | Samsung LA32A450 32 in. HD-Ready LCD TV
Screen is fuzzy
For best display on LCD monitor, you need to set the PC video resolution to the native resolution of the monitor, this monitor native resolution is 1280 x 1024 @60Hz.
Mar 29, 2010 | Acer AL1714 17" LCD Monitor
Have Dell Dimension 2400 and wanting to connect to Emerson LD195EMX.. attach to PC Monitor connection but no scrren comes up/// WHat else can I do?
Is the PC monitor connection - a DVI or DVI-I connection a 15-pin VGA connection an RCA video connection?
Have you set the television input to match the connector used on the TV?
The display resolution on your computer may not be set to a resolution your TV can handle. There is no point trying to put a 1280 by 800 signal into a VGA connector. Start with 640 by 480. However, this will not give you the high resolution you have come to expect from your PC's monitor.
This set also has HDMI input. If your computer has a DVI or DVI-I output, you can buy an adapter that will connect to that HDMI input. Note that this will only handle the video portion of the output from your computer and you will have to use analog connections for the sound and figure out which TV menu input selections allow high definition video with analog sound (not all sets can do this).
Note that LED TVs are not like CRT TVs where an electron beam can put a dot anywhere on the screen. An LED TV has fixed resolution modes.
It might be necessary to use a software product like "PowerStrip" to create a custom resolution mode that will show a high resolution image that will fill the screen of your TV. I wound up using 1352 x 648 to give a full screen image on my LED TV using the HDMI input. ("Your mileage may vary.")
There is a lot more to connecting a high resolution computer display to an LED TV than just plugging it into the "PC Input".
Jan 02, 2010 | Sylvania LD195EMX 19 in. TV
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
NO SIGNAL What do I do?
These messages are normal when the computer truly goes into suspend mode or loses the video signal (such as when the computer is suddenly turned off).
If the monitor displays any of these messages when the computer should be displaying video , do the following items until an image from the computer appears:
1.
Ensure the computer is really sending a video signal. To bring the computer out of suspend mode: move the mouse, press the spacebar, and press the suspend button on the keyboard twice (the suspend button has an icon that looks like a quarter moon).
2.
Ensure the video cable is connected (and connected to the correct video port).
3.
If you are trying to view video from a set-top box, DVD player or similar device, use its menu system to set the proper video output channel so that it matches the video connection are using. For example, if the monitor is connected to a satellite receiver via a second HDMI connection on the back of the receiver, select HDMI-2 (or similar) using the remote control for the receiver.
4.
Turn off the monitor using the monitor's power button and then restart the monitor.
5.
Cycle the power on the monitor as follows:
1.
Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
2.
Unplug the power cord.
3.
Wait 5 seconds.
4.
Plug in the power cord.
5.
Press the power button on the monitor to turn on the monitor.
One of two things happens:
1.
The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
2.
The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution.
6.
Adjust the Windows display resolution to a setting that is compatible with the monitor:
NOTE: The native resolution setting for your model of monitor can be found in the Monitor User Guide, the monitor's product packaging, and product specifications.
1.
Restart the computer and press F8 repeatedly after the first logo screen.
2.
Select Safe Mode .
3.
Windows should open showing a Windows desktop with lower resolution and fewer colors.
4.
In Windows Vista, click Start , Control Panel , and click Adjust Screen Resolution in Appearance and Personalization.
In Windows XP, click Start , Settings , Control Panel and then double-click the Display icon and select the Settings tab.
5.
Move the slider bar until the native resolution for the monitor is set, click OK and restart the computer.
6.
If the native resolution is not available from the slider bar, click Advanced Settings , click List All Modes (from the Adapter tab), select the resolution, and click OK .
If the native resolution setting is not available as a selection in Windows, you can temporarily use 1024 x 768 to complete these steps. However, you should update the graphics driver on the computer. Updating the graphics driver can provide more display resolutions to Windows; possibly including the native display resolution for the monitor.
Check for nVidia video driver updates at nVidia Home Page (in English).
Check for ATI video driver updates at ATI Home Page (in English).
Check for S3 video driver updates at S3 Graphics Home Page (in English).
Check for Intel video support and downloads, Intel Downloads (in English).
If you own an HP or Compaq computer, HP hosts video drivers and some video driver updates at the HP Software and Drivers site (in English)
7.
Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jun 15, 2008 | HP PAVILION A6230N DESKTOP PC
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
32 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
