Question about Cozy (W352E) Heater
I have a cozy dual furnace that makes a lot of noise when running it makes a snapping noise when heating very loud . The flame some times sounds like it is sucking to much air then it clears
  • 49 Answers
Measure from floor to top of grill should have 68 3/8 of an inch if not the header plate(separate part from unit) is installed wrong which can cause noise.
Posted on Mar 18, 2015
Therinnaiguy
  • 1420 Answers
SOURCE: Cozy dual wall propane wall furnance makes a loud
Blow out the burner tubes with air. Gas valve may be getting weak and not closing all the way.
Posted on Mar 01, 2010
  • 59 Answers
SOURCE: Cozy WOW 234 wall direct vent makes loud whistle
remove the back panel and check the blower for loose screws or debris like sealant tape. and the third pipe is the fresh air intake.
Posted on Oct 12, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Cozy wall
flue blockage, improper gas pressure or dirty burner
Posted on Jan 03, 2011
mc1bean
  • 3053 Answers
SOURCE: Have Cozy WOW403 Direct wall vent furnace the
Hello Dan, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
Let me know, Mike
Posted on Oct 31, 2011
SOURCE: installing high altitude kit on Cozy NG furnace
On the front of the burner where the gas comes out. If u pull the gas distributed tube out you will see the same " brass threaded cap", remove old one and install new one from kit.
Posted on Nov 04, 2013
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
WE HAVE A COZY GAS HEATER HAVE TRIED TO REPLACE THE THERMAL COUPLING AND THE HEATER LIGHTS AND SHUTS OFF AFTER FIRST CYCLE WHAT ELSE COULD IT BE IT HAS A HEAT SENSOR ON THE BACK COULD IT BE THAT
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 22, 2010 | Cozy (VCR502A-BM) Heater
My goodman furnace keeps lighting for about 10 seconds than goes out lots of clicking sounds
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad igniter what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.
Solution: You probably need to purchase and install a new igniter. I would suggest that you inspect your igniter closely for cracks. Make sure you do not touch the igniter with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, roll-out switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
NATE, NCCER, PHCC,HVAC Certified Instructor
Oct 25, 2010 | Heating & Cooling
My cozy furnace makes a loud clicking noise every time it is running. What can I do to fix this problem?
Wall furnaces sometimes do that it is just expansion and conttraction of furnace. rus
Mar 17, 2010 | Heating & Cooling
Very loud wall heater (bang!!) heat up and cool down.
cozy heat exchangers do tend to make a lil more noise than avg. if its popping before the blower comes on its proubly the heat exchanger expanding. you would have to watch the exchanger while it was heating to see exactly what is causing the noise. but as a renter you should try reporting it to the landlord first and try to get a tech there before digging yourself
Mar 15, 2009 | Cozy (W352E) Heater
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Flame Adjustment
Make sure the unit is operating on the correct gas, Natural or Propane (LP). The sound you are experiencing is either not enough gas and the flame is burning inside the burner port(s) or too much gas and the flame is much larger than it has to be. At any rate, get a technician to check the gas pressure entering into the home. NOW!
Sep 17, 2007 | Goodman GDS80904BNA Open Flame Heater
Cozy (W352E) Heater Logo
127 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
