Question about Whirlpool Front Tub Seal Bellow 8181850
Transmission problem on a 96 ford aspire
How to replace seals
    Sergeant:
  • 419 Answers
Buy new car such as may be 97 ford
Posted on Feb 03, 2015
I've got 96 Ford ranger 40 and did the complete gaskets on engine heads etc, but I am still pushing water out back side between manifold and the driver side above the driver side top transmission bolt
It sounds like the bolt goes through the jacket some times they do in witch case you need to seal the bolt boss with silicone or urathene just make sure you clean it good before you seal it
Sep 10, 2017 | Ford Cars & Trucks
1996 Bronco manual transmission hard to shift
You have a m5 (mazda 5 spd) transmission. Same thing that is in my 96 f150 4x4.
Ford had a problem with the slave cyclinders on thoes trannys. The slave is mounted inside the bellhousing and wraps aroung the input shaft, eliminating the need for a fork.
I am willing to bet my next paycheck that you have brakefluid inside the bellhousing.
Ford has a revision on that slave cylinder. because there is no dust boot on it, clutch material gets to the seal and tears it up, and because of the heat the seal will fail.
Replace your clutch, Flywheel (will have brake fluid burned into it), Slave cylinder, and possibly the line going to the slave (sometimes the realease locks up).
Make sure you get the slave from FORD, it is around $100.00, about 2x as much as anyone else but well worth it. I have not found anyone but ford make it with the boot and upgraded seal. If you get one from a parts store it will only last about 3 months. I tried, first one went out in 3 months, had it warrentied, then second only lasted 2.5 months. I finnaly brokedown and paid the extra for a FORD and it at 11 months it is still going strong.----------------------------------------------------
Launch X-431 IV Auto Scanner
Mar 14, 2013 | Ford Bronco II Cars & Trucks
Where do i locate the transmission fill on my 96 ford aspire with a manual transmission
it is usually on the side of the transmission about half way up, it is also the oil level for the transmission.....hope this helps.....cheers.
Jun 16, 2011 | 1996 Ford Aspire
When I start to drive my ford explorer the over drive light O/D come on and start to flashing. How I can fix the problem?
he overdrive off light flashing indicates that a problem with your
transmission has been detected. Take it to the dealer or a transmission
shop and get it checked out. If you continue to drive the Explorer with
the O/D OFF light flashing you can possibly damage the transmission.
Ford has issued a TSB on this problem. Has to do with a transmission oil pump defect and repair procedure.
Article No.: 97-22-4
Date: 10/27/97
Transmission - A4LD, 4R44E/4R55E, 5R55E - Torque Converter Slip - Diagnostic Trouble Code (Dtc) 628 Or P0741 Stored In Memory
Ford:
1985 to 1993 Mustang
1987 to 1988 Thunderbird
Lincoln-Mercury:
1988 Cougar
Light Truck:
1985 to 1990 Bronco II
1985 to 1997 Ranger
1987 to 1997 Aerostar
1991 to 1997 Explorer
ISSUE:
Some vehicles may experience excessive torque converter slippage, torque converter not engaging, or Diagnostic Trouble Code (DTC) 628 or P0714 stored in memory. This may be caused by damage to the fluid pump support seal and/or to the groove on the pump where the seal is located.
ACTION:
Inspect the fluid pump seal for damage. Refer to the following Service Procedure for details.
SERVICE PROCEDURE:
1. Follow normal diagnostic procedures as listed in the appropriate Service Manual.
2. Inspect the fluid pump support for damage. If damaged, also inspect the fluid pump support seal groove on the pump.
3. If the groove is damaged, replace the pump.
4. If the groove is not damaged, replace the fluid pump support seal with a redesigned Seal (F77Z-7L323-AA). Refer to Figure 1.
5. Do not replace the torque converter unless it is damaged or fails the criteria listed in the appropriate Service Manual and/or refer to TSB 96-26-12.
Jan 05, 2011 | 1998 Ford Explorer
Transmission is leaking where the two parts of the case come together need to replace the seal on a 96 saturn sl
that sounds like a front seal leaking. in that case, the transmission will have to come out. sorry. if leak is between motor and transmission, thats the front seal. hope this helps,,sometimes transmission stop leak does work,but only for short time. hope i helped..
Aug 23, 2010 | 1996 Saturn SL
I overfilled my transmission fluid on my 96 taurus gl, now it won't shift into gear. Did i blow the trasmission?
It is probable that you blew out the seals and will need your transmission repaired. You can try to slip a small hose down the dip stick tube and draw out the extra fluid, there is a slight chance that your transmission will work if you get the fluid level back down where it should be.
Jun 06, 2010 | 1996 Ford Taurus
Need to replace supercharged engine and trans. in a 96 Riviera
Faster and safer to drop the whole unit from the bottom with the cradle. Replace the supercharger snout bearing and seal before you install the replacement engine and the supercharger belt. Also replace the boost valve to your transmission just to ensure your getting the proper transmission line pressure throughout your transmission.
Thank you for using fixya and be safe
Jun 02, 2010 | 1996 Buick Riviera
96 Taurus; coolant leaks from radiator drain
the drain plug will have seals on it, just replace the drain plug. any parts store will have a drain plug/seal
Oct 19, 2009 | 1995 Ford Taurus
96 plymouth grand voyager, transmission slipping,not shifting
trans is shot very common problem you can rebuid it but thats not cheap finding a used one will be very difficult as 96 is a one year only model and there where 2 within that year depending on the buid date of the van
Jun 03, 2009 | 1998 Ford Windstar
Bad transmission leak
are u sure it isnt the rear transmission seal? they do wear out or sometimes they just go bad.if you drop the pan you will better be able to tell if its the seal or not.
Jan 29, 2009 | 1995 Ford Aspire
Whirlpool Front Tub Seal Bellow 8181850 Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
