Question about Huffy Cycling
Can't get gears to move on 6 speed huffy savannah women's cruiser to change
  • 1138 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Huffy Savannah
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look straight along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
THERE IS NO UPSIDE TO CROSS-CHAINING.
As you can see, the rear derailleur is probably not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
Ancient bike wisdom for beginners: If your legs ache, shift down. If your lungs ache, shift up.
Posted on Apr 25, 2011
  • 5386 Answers
SOURCE: i am trying to assemble
The only Savannah bike that Huffy lists is a 26" (700C Wheels) mountain bike. Some details are available here: http://www.huffy.com/Products/Product.aspx?pid=380'5'16 . Huffy has the assembly instructions available on their site: http://www.huffy.com/Support/BikeAssembly.aspx . The direct link to the manual is: http://www.huffy.com/ExternalLink.aspx?url=/pdf/ownersmanuals/b5cdef6e-94bb-4bfb-9996-832637c144b8.pdf .
I hope this helps. If you have a different Huffy bicycle, start here: http://www.huffy.com/Default.aspx .
Posted on May 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: i have a nirve 3
You'll probably find a workable adjustment here.
http://www.parktool.com/blog/repair-help/internal-hub-transmissions
Posted on Jul 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: HOW TO DOWNLOAD A FREE
http://www.huffy.com/Support/OwnersManuals.aspx
A search engine would have answered that instantly. No one makes unique manuals for any but the most unique models.
Posted on Jul 29, 2011
How do I adjust 7 speed shimano on Huffy?
Cable adjustment is complex. Suggest taking your bike to local bike shop for assistance
Sep 08, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
I am trying to assemble my bike, Huffy Ladies' Savannah Road Bike and don't have full instructions in the manual how many inches is Huffy Ladies' Savannah Road Bike ? 24" or 26"
May 27, 2011 | Cycling
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
I need instructions on when to change gears on a 15 speed, 24'' girls bike. I bought it second hand, and have no idea which gears to use when.
biggest in the back and smallest in the front gives you the fastest accel and is used for uphill as well.. smallest back and biggest front is used for top speed....
Aug 18, 2009 | Huffy Alpine 26 Women's All Terrain...
Operator manual for huffy crosswind bike grip shift
Jul 15, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Cycling Logo
51 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
