Question about Activa Watches
Activa watch battery replacement
How to change batteyr
Changing battery iI lost the screws
you might find them on your floor later but to find new very doubtlfull
Mar 29, 2015 | Activa Watches
I have recently bought an Activa watch (white leatherette strap/white pearl face/roman numerals at the 12,3,6 & 9 position) at an antique shop. It was indicated to me that all it required was a new...
Hi knbaker59; If you already replaced the battery and still not working then it will stock the machine. Its needs to clean or overhaul the machine,so it will work again and if you already clean the machine and still not working then the problem is the circuit block need to replaced a new one. Hope it may help. Feel free to ask whatever the result.
Regards: votit
Apr 10, 2011 | Activa by Invicta Casual Brown Pearl Watch...
Activa AD 044 digital watch. Came without
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals. Rate me, please .
Apr 07, 2010 | Activa by Invicta Midsize Digital Watch...
I bought this watch and misplaced the manual for it and can't set it. Activa water resistant register no. 495494 AD639-008 yellow
Click on my profile (escapement), then click on Tips and Tricks. There you will find links for all watch manuals.Rate me, please.
Mar 17, 2010 | Activa Watches
How to set time
ACTIVA is made by INVICTA, so, it uses the same watch movements as INVICTA does. Click on my profile (escapement), then click on Tips and Tricks. There you will find a link to all INVICTA watch movement manuals. Rate me, plz.
Feb 25, 2010 | Activa AD009 e Watch for Women
I can't turn off the hourly beep on my Activa watch.
If you haven't got a manual and there are no stockists in your locality, then try the following (based on other similar watches).
Press the mode button several times until you come the alarm function. There should be an hourly alarm or beep alarm or something similar (they are likely to be abbreviated), so you may have to play detective.
When you think you have the correct setting (beep ON?) press one of the other buttons to see if they change ON to OFF.
When you are satisfied with the setting press the mode button to return to normal operations.
Good luck.
Jan 28, 2010 | Activa Watches
I have an activa lithium water resistant watch #AD632=010. The light works but the digital clock doesn't.
If there is no time displayed the watch is just dead. You can try a new battery or just get a new watch.
If you can't seem to set the time: Press and hold Mode until it flashes a time and the letter A . This is how you set the alarm. Press mode again and you can set the time. start stop button moves between seconds, min., hrs, and days. reset changes the value.
How do you turn off alarm on activa AD050 watch
in the normal time mode,  hold down the start button (this also shows the current date)  and then press the reset button to toggle on/off the alarm
Dec 15, 2009 | Activa Multifunction Digital #AD050005...
Watches Logo
57 people viewed this question
Top Activa Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you an Activa Watch Expert? Answer questions, earn points and help others
