Question about AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Intel 845gvsr motherboard is dead
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No diaplay, no beep.
I want technical guidence,please help me.
Jaikumar Peddy
  • 1 more comment
  • Jaikumar Peddy Nov 03, 2007
    I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When RAM is installed the board does nothing. No diaplay, no beep.
    Jaikumar Peddy
  • podi Nov 27, 2007
    i followed the steps below
    replaced cmos battery,clear cmos,change the smps,tried with pci vga card,checked wih the 256mb ddr 333mhz ram but the board is in dead condition
  • ahmedakl_eg Jun 09, 2008
    exact the same problem
    i tried all the solutions, change battery, change processor & ram And power supply
    no way
    i need help
  • 46 Answers
Try a new power supply
Posted on Jan 28, 2008
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Intel Server S5000VSA gives 3 beeps and no BIOS display.
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
Feb 19, 2009 | Intel S5000VSA Motherboard
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
845gvsr motherboard dead
near by ram slot 10 ohm registance serial smd register check
some one register bank fail{beetween cpu and ram slot}
Mar 07, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
AOpen XC Cube MZ915M (95MZ1592Z1) Barebone Logo
300 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
