Question about Pioneer TS-A1673R Coaxial Car Speaker
Does my door speakers connect to my wires inside my car
    New Friend:
  • 33 Answers
Your door speakers run to the rear of the radio unit in your car.
Posted on Dec 13, 2014
2008 avalanche the radio has issues, the post speakers work all the time, sometimes front right speaker works othe time rear left whats the DEAL?
First check the speakers wiring, due to the car movement these wires tend to break or create a bad connection, at the doors they break at the passage of the door to the body, inside a rubber coil. The speakers also can get wet due to water infiltration, so check for it too.
Oct 24, 2015 | 2008 Chevrolet Avalanche LS
Ford escape door
take inside panel off to disconnect the wire harness that goes to your window switch and speaker. remove the door pins and bushings and door will come off. dont forget to route your wire harness before putting the door panel on the new door. connect everything in reverse order.
Dec 29, 2013 | Ford Escape Cars & Trucks
How to remove 199 windstar electrical/audio door connector?
Drill out the rivets and replace with short bolts. Rivets are common inside doors.
Sep 28, 2017 | 1999 Ford Windstar
How to replace rear door speakers for 1997 GMC jimmy
I think your GMC have in-door rear speakers.!!
  • Look for screws in door panel or around the speaker vents.
  • If you are sure that the speaker cant be removed without opening the door panel then read this below.
  • Mostly seen near areas like door lever(inside), power window switch set, bottom and each sides of the whole panel.
  • If its manual window, then look for a circle clip in between the winding window lever and the door panel. Plunge screw driver between them a make a gap then look.
  • Assure that all clips or screws which obstacles the removal of the panel.
  • Simply pull the panel from sides towards you
  • If its completely open, then locate the speaker and unscrew it.
  • Check the connection wires for quality
  • Mostly its good to scratch the leads of the wire to remove copper oxide layer
  • Take the new speaker, check the holes on the door matching the speaker's
  • If needed, drill hole for screw and be sure that the new speaker is not more than 15cm diameter.
  • Connect the leads, fix the speakers.
  • Check the sound clarity with your car audio on.
  • If everything is perfect.. go on , fix the door panels
  • Mainly sure with the side clips of the panel, do not bent or break them.
  • Check for any balance parts or screws.
  • Screw everything back as normal.
  • You just installed a new speaker....
  • pls rate it!!
Sep 23, 2011 | 1997 GMC Jimmy
All the speakers including the sub do no have any sound coming off. The only speakers that have sound coming from them are the very last ones in the back seat. How can I fix this?
Check the wiring of the speaker that don't work, it might have been disconnected or the wires are cut.
Look at the wires inside the door panel, which the front speaker is located, the wires leading to it might have disconnected via door panel wire harness inlet. You could see the wires at or near the front door pillar hinges.
If the wire is cut off, strip the wire and join them together, wire color should be connected with the same color. After that insulate them by using electrical/plastic tape.
Your local technician can repair it.
Hope that helps you out.
Thanks for using Fixya!
Jul 10, 2011 | 2006 Nissan Sentra
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
1993 Subaru Loyale speaker wiring
check the colors of the wires in the door, and look on the back of the radio to see if they are located there too, if so then yes they are connected.
Jul 05, 2009 | 1993 Subaru Loyale
Power lock and dome light does not come on when door is opened.
I had the same problem with my 2005 dodge ram 3500 and found the wires were being pinched that run through the rubber boot on my right rear door. I had this fixed by dodge but there splice didn't last, so I took some 16ga wire and spliced it into the wire that operates the power door lock on that side and it fixed the problem. Dodge service shop did a sad job of splicing the wires back together by twisting the wires together and tape and wire broke.
Feb 21, 2009 | 2004 Dodge Ram 1500
Pioneer TS-A1673R Coaxial Car Speaker Logo
89 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
