Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Recieved new printhead have same problem pages arecoming out striped white gray black strips across whole page
  • 295 Answers
Caliberate ur printhead once again.. or else kodak will replace ur printer free of cost.
Posted on Jun 22, 2009
The printer skips at the middle of the page
If I recall correctly, this printer uses a calibration strip to tell where the printhead is.
It's an almost invisible strip of plastic (may look gray) the runs the entire width of the carriage.
It's not gray, in fact it's clear with black stripes, and that's how the head tells where it is.
If this strip gets ink or other contaminants on it, the print head will "skip" over that area thinking the dirt is one black line (one pixel wide).
Repair houses stopped telling people to clean these strips ages ago because people would apply too much pressure and pop the strip off the catch or the spring that holds it - or worse - break it.
If you are very gentle though, you can use a Q tip with distilled or bottled water to clean it.
Only use rubbing alcohol if the water doesn't work, as the inks are usually water based and water soluble.
Feb 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Black 3e Cartridge
check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Jul 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
Jul 18, 2009 | Sony Car Audio & Video
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
Drb4375 wiring diagram
Gray and Gray/Black stripe Go to front Right speaker
White and White/Black stripe to Front Left speaker
Purple and Purple/Black Strip to Right Rear speaker
Green and Green/Black Stripe to Left Rear speaker
Yellow to switched +12 volts. Only on when keyswitch is on.
Blue to Amp Remote
Red to full time +12 volts
Black to Metal negative ground
Dec 02, 2007 | Clarion DRB2475
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
