Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
How to tell if a sony wega tv bulb is bad - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Slinteriors
  • 8617 Answers
SOURCE: Sony Grand Wega KDF-E42A10 50in LCD projection TV
There is a bulletin from sony for certain sets with your model number failing to power up and needing a free software update. go to the following link and fill in the info on your set your set may be affected .
http://esupport.sony.com/US/perl/swu-download.pl?mdl=KDFE42A10&upd_id=2075&os_id=25
Posted on Apr 09, 2008
rob52078
  • 40 Answers
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Posted on Mar 18, 2009
stonephoenix
  • 563 Answers
SOURCE: wega KDF-50WE655 has purple spots, support says wega engine bad
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described sounds like one of the circuit boards that control the picture quality needs to be replaced. The cost of the board would likely be in excess of $200. There are usually several boards in a TV like that that control the picture and when one goes, you can get anything from lines in the picture to poor picture quality from blurriness. The main question is do you want to spend $1000 to fix a used TV?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
techman007
  • 1112 Answers
SOURCE: i have the sony wega 60 lcd tv, it turns on ok then shuts off
How long have you had the set? If its been at least two years then its time for a new lamp.
Thanks
you can email me at Delhielectronics@live.com
if you need futher assistance. I believe your lamp is faulty...
Posted on Sep 27, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Posted on Oct 17, 2009
Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television: my sony wega 55'' tv is telling me that the projec...
If you have not done it before I would recommend changing the entire assembly. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix this and where to get the parts. Thanks for using FixYa and for the generous rating.
hardrocko
May 05, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv not working
Bulb may be bad or the lamp housing is damaged from heat. The plastic housing warps causing the micro switch that tells the tv the bulb is in goes out of alignment and the tv thinks the bulb has been removed
Aug 25, 2009 | Sony Grand WEGA KF50SX300 50" Television
The red lamp light comes on and the tv does not start
Possible bad bulb or bad lamp housing. These tvs have lots of heat near the lamp and the micro switch that tells the tv the bulb is in may not be making contact anymore from warpage in the plastic surround
Aug 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
