Question about Xerox Phaser 6350DP Laser Printer
Xerox 6350 printing light black
Black printing light
SOURCE: xerox 8825
hi im jules_09.have you tried changing you cleaning blade or roller?if yes check the exposure lamp my its deffective if not.also black copy is cause by over tone developer is also deffective
Posted on Oct 04, 2007
SOURCE: can't print when there's only black ink
Here's a trick that worked for me - there are two tiny prisms on the back of each ink cartridge, to refelct light to a sensor indicating whether there is or is not ink in the cartridge. Simply put a small piece of masking tape over the non-mirrored prism, i.e. right next to the mirrored prisms, to make the printer think the cartridge is full of ink. Put the small pieces of tape on each of the three empty color cartridges, being careful not to cover up the mirrored pieces, as light relected from these indicates that there is a cartridge in the slot. The printer will run as if it has full black and color cartridges, but set your defaults to only print black.
Posted on Jan 28, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8500 not printing black
Here are the directions to enable and disable Jet Substitution. This may very well help.
Some of the print head jets will not unclog for you. If that does not work then most likely the print head needs to be replaced.
o enable the Jet Substitution mode:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. If necessary, select [Print Light Stripes Test] to make a Light Stripes Test print that shows any weak or missing jet and its jet number.
  5. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  6. Press the [Up] or [Down] arrow button to select the color for the weak or missing jet, and then press the [OK] button to select the color.
  7. Press the [Up] or [Down] arrow button to select the number of the weak or missing jet (1 to 309), and then press the [OK] button to confirm the selection.
    NOTE: If necessary, press the [Up] or [Down] arrow button to select [Save Change and Select Another Jet] to substitute more jets.
  8. Press the [Up] or [Down] arrow button to select [Save Change and Exit] and then press the [OK] button to complete the procedure.
To disable the Jet Substitution mode:
  4. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
Posted on Feb 16, 2008
SOURCE: xerox phaser 6250 is not printing black
I did a combination of the things listed in the below link.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=180,E=0000000000023462887,K=8165,Sxi=16,Case=obj(19377)
Posted on Dec 30, 2008
  • 159 Answers
SOURCE: Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
Posted on Oct 26, 2009
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Xerox 6350 prints to much magenta
is it also when you print blank pages after the 25-50 pages? if so it could be the fuser, if not it could be the imaging unit. Check your magenta imaging unit and fuser roller anyway. If any of them is dirty, replace them.
Dec 02, 2013 | Xerox Phaser 6350/YDT Laser Printer
Xerox phaser 6350 has stopped printing on two sides. Have document which did print correctly two weeks ago, now does not.
you need to change the settings again on the printer driver itself:) when printing choose the printer and the settings under printer properties
Nov 20, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
Oct 23, 2009 | Xerox Phaser 6130 Laser Printer
Xerox 6350 prints ghost page every page printed. It is printing a ghost imge of the previous document printed on every page.
If the ghost is black then you might have a bad Black Developer 116-2011-00
If the ghost is in all colors then it may be your fuser, or possibly just your paper settings. (If you are using glossy paper or card stock this needs to be fed from the MPT tray and defined correctly in the control panel)
Whit
Item, Inc.
Oct 13, 2009 | Xerox Phaser 6350/YDT Laser Printer
Black printing is very dull but colors are bright in Phaser 6130
I have the same problem with a 6350 Phaser. Did you get it fixed?
Jun 11, 2009 | Xerox Phaser 6130 Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Xerox Phaser 6350DP Laser Printer Logo
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
