Question about Refrigerators
Zel gvy53ad relay
THEMAL SWITCH
Code128 seems like fan motor wont stop running with ignition on?
Sounds Like The Themal Switch Is Stuck On Or The Fan Relay Is Stuck In The On Position ,
Try Removing The Fan Relay .
Listen To Hear a Clicking Sound When Plugging In And Out The Relay
If You Do Then Check The Thermal Sensor .
If You Unplug The Sensor And The Fan Goes Of With The Engine Cold Then That Is Your Fault
Good Luck
Gordon MacLean
Mar 20, 2014 | 2003 Chevrolet TrailBlazer
Does a 2002 jetta TDI have a themal A/C cut out switch?
No, it uses the engine temperature sensor and rad fan module.
Aug 27, 2013 | 2002 Volkswagen Jetta TDI
What is the meaning of the name hazel anne ?
Hazel is a name conferred upon a girl. The name is pronounced as "HAY-zel." It is originated from German. Hazel means love,full of hope,and trust. ?
Aug 31, 2011 | Apple QuickTime VR Authoring Studio 1.0
Freezer running continually and not cutting in and out .Alarm light is onlo
you have to replace your themal control switch before you burn out the compressor
Sep 27, 2010 | Freezers
What is the turkish word for beauty? what is the turkish word for scents?
Beauty in Turkish is noun
  1. güzellik
  2. güzel
  3. güzel k?z
  4. güzeller güzeli
  5. nadide parça
  6. güzel yan
Scents in Turkish is kokular Curtorsey: http://www.stars21.com/translator/english_to_turkish.html
Apr 07, 2010 | ArcMedia ABC of Baby Names
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
The fan stays on
You should have (located in a radiator) a themal switch that senses temperature to turn on the fan. Unplug the wiring from it to see if the fan stops. If this fails, it can do what you are saying.
Aug 08, 2009 | 2002 kawasaki VN 750 Vulcan
I have a whirlpool gold gas drier that wont put out any heat any advice?
thermal switch or element. Check continuity of themal switch.
Sep 01, 2008 | Whirlpool Dryers
Replacement for Skybox compressor
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Mar 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
