Question about Blendtec Blenders
Too many chunks leftover in the blender - Blendtec Blenders
Need a replacement jar
  • VillaWare V001-43100 Pro Infinity Blender - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16896115006
    • 2/5
    • 2 REVIEWS
    Buy VillaWare V001-43100 Pro Infinity Blender with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Oster® Blender Parts: Find by Model ' Oster® Canada https://www.oster.ca/en_CA/parts-and-accessories/blenders Pick your model and see all of the blender replacement parts available on Oster.ca.
  • VillaWare V001-43100 Pro Infinity Blender Overview - CNET www.cnet.com > Appliances > Small Appliances VillaWare V001-43100 Pro Infinity Blender overview and full product specs on CNET.
  • Model #43100 Need a plastic Jar replacement. Where can I ... www.fixya.com > Forum > Blenders Model #43100 Need a plastic Jar replacement. Where can I find one. Where can I get replacement parts - Blenders question
  • Tilia 1000W Moderno Blender ' TheFactoryDepot thefactorydepot.com/Tilia-1000W-Moderno-Blender/M/B000GFG2W4.htm Tilia 1000W Moderno Blender: MODEL- V001-43100 VENDOR- VILLAWARE FEATURES- Moderno Pro I
  • VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz ... www.tigerdirect.com > Appliances - > Blenders - VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz, 1000W, Speed Setting Dial Item#: YYD1-V43100 ' Model#: V001-43100
  • Oster Blender/Mixer Parts ' Reliable Parts https://www.reliableparts.ca/catalog/592809 You Are Here: Home > Small Appliances, Parts & Accessories > Oster Blender/Mixer Parts A selection of Oster ... Search by Model of Appliance:
  • Amazon.com: Customer Reviews: VillaWare V001-43100 Pro ... www.amazon.com/VillaWare-V001-43100-Pro-Infinity-Blender/product... Find helpful customer reviews and review ratings for VillaWare V001-43100 Pro Infinity Blender at Amazon.com. Read honest and unbiased product reviews from our users./>
  • Parts for the Blender at VillaWare.com. www.villaware.com/parts/parts-by-model/parts-for-the-villaware... Shop the Parts for the Blender at VillaWare.com. Food, Passion, Life.
  • http://www.bing.com/search?q=blender+Model+43100+parts&qs=n&form=QBRE&pq=blender+model+43100+parts&sc=0-25&sp=-1&sk=&cvid=F6D21CC73446407E940EA71DFB37D5F2
    May 20, 2016 | Blenders
    Blender is leaking
    As we all know that blender is an electronic device from which you may face some problems while using it. One of the main problems is leakage, the neckline and gasket are the first problems that will give some inconvenience to you, it is a most critical part of your blender because they keep it sealed or water tight. I would suggest you the Best Blender Under 100 which is on your budget also.
    Sep 18, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
    My 5-year old Vitamix 5000 has started leaving chunks of ice not blended. The motor seems to be working OK and it doesn't sound any different than usual, but it has always done a better job of...
    Hello, afreden
    I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
    repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
    Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
    Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
    Thanks, Mike
    http://beta.fixya.com/users/mc1bean
    Sep 12, 2011 | Vitamix Super 5000 Work Top Blender
    My vita-mix just stopped working, there is slight burned smell, I was blending walnut pieces with dates paste. Any suggestions?
    If the burning smells like plastic then the walnut shells most likely put too much strain on the motor and burned it out. If the burning does not smell like plastic then you most likely have walnut shell grit jamming your motor.
    This can be cleaned out by first ENSURING IT IS UNPLUGGED FROM THE WALL.
    • First remove the canister (if possible)
    • The remove the blade (if possible) check for a build up of grit between the blade and the shaft connecting it to the motor.
    • Check the channel the shaft passes through from the motor for large chunks of walnut shells or date paste.
    • Clean the canister thoroughly with warm water and leave it to soak overnight in a water/soap mixture.
    If this has not resolved the issue then try to claim it under warranty or source replacement parts online.
    Feb 28, 2011 | Vitamix Super 5000 Work Top Blender
    Will not blend the ice
    You may need smaller ice chunks, this is usually a physical issue, look at it and see if ice is stacked in a manner to block more ice from getting to the blades.
    Oct 03, 2010 | Helman Group Nostalgia Electrics MMA-600...
    My kenmore blender stopped blending!!!
    There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
    Oct 06, 2009 | Kenmore Blender Single-Speed Blender
    The blender and lcd countdown is on...blender
    If so, it's underneath the unit. If so, unplug it before resetting.
    Oct 06, 2009 | Breville CBL10 BlendMaster Classic Work...
    My blender with the rubber part on top (black piece) of the motor actually disintergrated while in use. Motor is fine, just that the black rubber that fits into the glass part that makes the turning is...
    call manufacturer if still under warranty they will replace most times for free if not under warranty buy part google name and model # see what that brings up! Best of Luck to you!!!
    Jun 28, 2009 | Blenders
    Leaking Blender
    yes you have a defective rubber seal on the pitcher base
    Apr 16, 2009 | Back to Basics Blender Solution 5500...
    Blenders Logo
    Top Blendtec Blenders Experts
    eyecam
    Are you a Blendtec Blender Expert? Answer questions, earn points and help others
