Question about Husqvarna Viking 1
How to wind the bobbin on a Husquvarna 750
How do I wind the bobbin on this machine?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Suggest checking the user manual. Manuals can be viewed, downloaded, or printed at http://www.manuals.husqvarnaviking.com
Posted on Oct 16, 2014
  • 201 Answers
SOURCE: Bobbin stuck on winder
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
Posted on Jul 24, 2009
  • 371 Answers
SOURCE: Have a husquvarna viking 200 machine and the
I'm assuming you are talking about the rewinding mechanism on top. There are grooves in the bobbin which fit on to the rewinding spindle that holds the two together while the bobbin fills. It may be they have gotten out of synch or the bobbin is a non-standard Husqvarna Viking bobbin for that machine. These usually use green bobbins but they have come out with new colors but all have the Husqvarna logo on the bobbin -- an H. I would try to wiggle it slightly to try to remove it. If still will not come off, try popping it off with a flat head screw driver but be sure to put a folded towel under the screwdriver so that you don't damage the molding of the machine. If you still are unable to get it off, recommend taking it to an authorized Husqvarna Viking dealer. A list of dealers near you is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
  • 152 Answers
SOURCE: How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Posted on Nov 02, 2009
  • 371 Answers
SOURCE: bobbin won't wind
The bobbin rewind unit needs to be inspected. In order to do that the covers have to be removed. It could be the wiring to the board may be disconnected or the rewind unit is just broken and needs to be replaced. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
SOURCE: bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Posted on Apr 07, 2010
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
Thread won't wind on bobbin. Just goes up and down and never swings thread around bobbin,
you have to loosen the hand wheel clutch to stop the up down motion then perhaps the bobbin with turn
Feb 06, 2017 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Do not know what size prewound bobbin i need to buy for a white 3300 embroidery machine
try this link, sewing parts on line says this is the bobbin for your machine, compatible with some Whites and Husquvarna Viking machines.
http://www.sewingpartsonline.com/bobbins-viking-white-10-pack-4120612-45.aspx
Genuine Part #412 06 12-45 or alternate code is 11770P
Jun 06, 2011 | White Sewing W3300 Computerized Sewing...
I took my Viking Husquvarna Sewing Machine (Model 5605 Rose) apart and cannot figure out how to put the clip back in on the inside. I need a photo of the internal schematics for the machine.
I just got a Husquvarna Viking, Rose machine, i do not know how old it is, but i can't find the model number, and i wuld also like to see how the bobbin case should look.
thank you, Graci
Mar 27, 2010 | Husqvarna Rose
Oct 15, 2009 | Husqvarna Viking 1
Jul 21, 2009 | Husqvarna Viking 1
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
