Question about Kenmore 3.2 cu. ft. Top Load Washer
I have a Kenmore Catalyst washing machine, model #110.20056 992, that is triple beeping and only allowing one wash cycle type. Is there something I can fix on this?
  • 15,935 Answers
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 19, 2010 | Kenmore Washing Machines
Beep while wash cycle on
The beeping is indicating that something is wrong, it is usually followed with an error code or flashing lights.depending on the model
I would advise you to refer to your user instructions.
Hope this helps with your problem.
Thankyou.
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore washing machine makes a squeeking noise
Sounds like you have something between the tubs. If it only does this in the spin cycle, I would look for something between the tubs
Please rate solution if helpful
Aug 24, 2009 | Kenmore Washing Machines
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Washer will stop in middle of cycle
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
Clean Cycle
I had the same problem. After unplugging and plugged it in several times, I got it to switch to a wash cycle. But now it beeps every 20 seconds.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
111 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
