Question about Samsung Heating & Cooling
PBA means for aircon - Samsung Heating & Cooling
What does exactly means 'INSP' in the aircon display of GW X240 4WD?
I am not sure something inspection or service,may you have to take to dealer.
Oct 11, 2016 | Cars & Trucks
What dose it mean?wait image2...
Dear
You can try to upload the higher version firmware, some times it may revive the main PBA. The alternate is to replace the main PBA. But if some professionals are doing chip level repair and programming then you may take their help to restore the main pba.
Thanks.
Mar 08, 2015 | Samsung SCX4623F Laser All-in-One Printer
How to solve samsung scx 4300 download from pc error
Dear
Its meaning is the printer is ready to download the firmware from pc. This may caused due to some error with either internal data or man made error. This may be over come simply try to download the firm ware if its update then fine next clean the main pba with isoprpyl alcohol dry it and test else replace the main pba.
Thanks.
Mar 08, 2015 | Samsung Office Equipment & Supplies
Device 22 toshiba fax
okay. Solution pertains to device errrors 22 thru 25.
step 1: Is the cable from the fuser firmly connected to the Low Voltage Power Supply at (CN3), between the mother PBA (Cn24) and the Main PBA (Cn12)?
step 2: Is cable from fuser firmly connected to the mother PBA (CN4) between mother PBA (CN25) and the Main PBA (CN13)
step 3: if connections seem good and problem error code persists, replace in this order:
1. Fuser (call 888)690-7283 to order.
2. Low Voltage Power Supply
3. Main PBA
4. Mother PBA.
Oct 20, 2011 | Toshiba DP120F All-In-One Laser Printer
Toshiba DP 125F What do these status codes mean: a)NG B0 b)50 Also how do I fax to a long-distance number if adding long distance code?
If you mean by "50", Device Error 50, make sure the cable is firmly connected between the main motor and the Mother PBA (CN3), between the Mother PBA (CN24) and the Main PBA (CN12). Otherwise, replace in this order:
1. Main motor.
2. Main PBA
3. Mother PBA.
Jan 12, 2011 | Toshiba DP125F All-In-One Laser Printer
Same situation with warmlyquid.. after reformatting, i got trouble having no audio mixer resulting to no sound.. Samsung Harappa 30 PBA: BA5900905A Rev. MP 1.1... i tried to search it to the samsung's...
try this links:
http://driversdownloaddriver.com/tag/driver-motherboard-samsung-harappa-30-pba-ba59-00905a
http://ptf.com/samsung/samsung+harappa+30+pba+59+00905a+sound+driver/
maybe it will help you..
Mar 08, 2010 | Computers & Internet
Samsung scx-4521f lsu erarr problam
kindly check the LSU main pba cable damaged or not ?
no problem found, kindly check with the replacement of Main pba or LSU.
Feb 26, 2010 | Office Equipment & Supplies
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
Chris asks. My Samsung SCX-4200 is showing ( add paper no paper and PC print pending ) on the led
Check and Cause:
1. Deformed paper sensor actuator or faulty sensor.
2. SMPS PBA or Main PBA is defective
3. Faulty cables or connectors.
Solution:
1. Replace the defective actuator or sensor.
2. Replace the SMPS PBA or MAIN PBA as
appropriate.
But better - take MFP to authorised service center
Nov 30, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
