Question about Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator
Need service manual for kenmore model 59673503200
Need service manual
2 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: I have a kenmore elite french door model
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout.......
Posted on Aug 10, 2010
Looking for a users manual for a Sears Kenmore sewing machine model 158.120, not a parts manual.
I would first try Google and ask for service manual for your model. A close model match may do the trick as usually very little variation in same model series. Also, if you locate a Sears service center nearby, they may be able to help you find or instruct you in what you need . Good hunting
Jan 03, 2017 | Kenmore Sewing Machines
I have a Kenmore/LG Fridge that leaks - does anyone know where I might find a service manual?
Good luck on finding a service manual but providing your Kenmore Model number will help me provide the help you may need to resolve the leak problem. A Kenmore sold LG model number begins with 795. I also need those number after the 795.xxxxxxx A description of the leak problem would also help
APPLIANCE911
Apr 16, 2016 | Refrigerators
I NEED THE OWNER MANUAL FOR MODEL # 15818034.
Sears Parts Direct has a portion of the Service manual for the Kenmore 15818034 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-Machine-Parts/user-manuals/manual-downloads/Model-15818034/0582/1200000?modelNumber=15818034&diagramPageId=&documentId= . However, the owner's manual for the Kenmore 158.1803 should help you since it is from the same line of sewing machines. This manual is available from SewUsa here: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/1803_Instruction_Manual.htm . It's also available from Sewing Parts Online here: http://www.sewingpartsonline.com/instruction-manual-kenmore-158-18030.aspx .
I hope this helps.
Feb 03, 2016 | Kenmore Sewing Machines
Kenmore 385.18221 auto bobbin shut off does not work how to fix? where to get repair manual?
Hi Freysauto,
You can obtain the Owners Manual here: Instruction Manual Kenmore 385 18221 Models
'Manage My Life' reports "There is no service manual offered for your model sewing machine. Some of the older sewing machines didn't have an owner's manual and service manuals were offered for them. There is an owners manual for your sewing machine, but no service manual." Can download service manual for Kenmore sewing machine 385 18221...
Good luck.
Feb 12, 2015 | Kenmore Sewing Machines
My kenmore elite refrigerator model number 59673503200 freezes the food
Check the thermostat may be broken or close control air flow in cooler compartment, this is very much open and circulate air from a freezer to the maintainer
Nov 03, 2014 | Kenmore Refrigerators
Service manual for Kenmore 385 sewing machine
You probably can't, unless you know a repair person who'd be willing to lend you his/hers. http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851884180/0582/1210000?pathTaken=&prst=0&shdMod=3851884180 is the parts diagram for this machine.
However, I know of no "string" associated with a stitch selector on any machine, so I'm wondering if you might need a pro to help...
Feb 11, 2014 | Kenmore Sewing Machines
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Nov 03, 2017 | Refrigerators
Need a Kenmore Serger manual
The manual can be bought from here if it is one of the model numbers listed: http://sewusa.com/Sewing_Machine_Manuals/kenmore_Sewing_Machines.htm for $6.25 or here http://www.ucanprint.com/ for $10.
Kenmore has a searchable database of manuals here http://www.kenmore.com/shc/s/nb_10154_12604_NB_CCownersmanuals?adCell=WF&i_cntr=1298919841504 but they might also charge and you need to know your model number.
I can't find it for free, but you might try contacting Kenmore customer service at 1-888-Kenmore or through their online form at http://www.kenmore.com/shc/s/nb_10154_12604_NB_CCemailus?adCell=W5.
Or if you have a specific problem, we can answer that without the manual.
Feb 28, 2011 | Kenmore Sewing Machines
I need the electial diagram for my kenmore washer model 110.20702990.
See the following two documents:
The first is the Sears parts list including major component diagrams and parts / prices:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jan 04, 2011 | Kenmore Washing Machines
Kenmore Elite TRIO® 7854 (25 cu ft) Bottom Freezer French Door Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
