Question about HP LaserJet IIp plus Printer
LaserJet IIIp will not print using USB to parallel cable via Vista
    Scholar:
  • 122 Answers
DOT4 USB Printing support must be installed and the printer setup on a USB port in the printer manager for this to work. The laserjet 3p driver provided by Microsoft does not natively support DOT4 USB printing, as USB was not even invented when that printer came out. You might be able to enable this support by using the HP Universal print Driver instead of the built in driver provided. You can get the universal driver here:
Posted on Jun 19, 2009
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
HP laserjet 4L parallel to usb vista Jumbled font on test page
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
Feb 21, 2009 | HP LaserJet 4L Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
HP LaserJet IIp plus Printer Logo
381 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
