Routers i want to connect two zyxel router on nilled-up line point to point how can i do how can i configured.
  • mannis1 Nov 02, 2007
    zyxel 200 series
  • 404 Answers
HI! if ur plan is to cascade to routers here is what u can do..
Uplink port to WAN Port
router 1 have port1 port2, port3 port4 and WAN port
rouer 2 have port1 port2, port3 port4 and WAN port
Configure first the ip address of the 2nd router before connecting to the 1st router..
ex. the ip address of the 1st router is, your are goint to change the 3rd octet and the 2nd router ip should be 2 is the 3rd octet..
your cable connection should be.. the ethernet cable from the the modem will go the the WAN port of the 1st router and you will connect another cable at the router1 on port4 going to the WAN port of the 2nd router.. this should work..
Posted on Aug 13, 2009
  • 47 Answers
I don't understand what you want to do. I need specific details of what you want your network to do.
Posted on Nov 09, 2007
How do i fix connection for router zyxel wap3205
Turn your DSL/cable modem off.
Turn your ZYXEL router off.
Turn your DSL/cable modem on.
Turn your ZYXEL router on.
Restart your computer.
You should now have an Internet connection.
Mar 05, 2015 | Zyxel WAP3205 Wireless Access Point -...
How to change Pass word
Hello it depends on your router.
Read more here:
Here is a video that shows how:
You might have to reset router to access the page.
Press the reset button at the back of your router for 30 sec.
and release.Wait for it to boot up again.
Now the router is set to factory settings.
Connect your lan cable to the router to one of the ports 1 to 4
and to your computer
To configure your router's wireless network open Internet Explorer and navigate to the router's configuration page by typing into the address bar. When the page loads you will be prompted for your Router configuration password. By default this is 1234.
(You have to find the username and password first)
Try to download a manual for the router:
Please select your model and number.
Do not use a easy password so others can use your internet connection.
Good luck
Nov 03, 2012 | Zyxel Computers & Internet
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have...
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Jul 09, 2011 | Zyxel P660HW-D1 Router
I am trying to configure my new NBG4115 3G router connexion, but when I try to connect to the Zyxel setup screen via the Tilgin home screen appears. My present router here in our home is...
Either your web-browser has "cached" the web-page previously delivered by the TILGIN,
or your computer is still connected to the TILGIN.
In the former case, "reload" the web-page.
In the latter case, turn off the TILGIN router, and try again to connect to the ZYXEL router.
Also, check that your network-cables are correctly connected to one of the LAN ports on the ZYXEL router.
May 12, 2011 | Zyxel NBG-415N Router
Two access points don't work
1. check the distances of the access points.
If over 300 hundred feet you will loose.
2. check the main router to verify access points are configured in it.
Apr 19, 2010 | Zyxel Prestige 600WH Wireless Router...
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) virtual...
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
Nov 10, 2008 | Zyxel Prestige 334 Router
How to configure in point-to-point
To connect both offices you have to create a VPN between both end's so that you can make a safe data tunnel between these two office. for this you have to static IP's on both ends and a Third party VPN client software.
for more details you can mail me i'll provide you all the details for how to create a safe VPN between two points.
Mar 18, 2008 | Zyxel Prestige 660H Router
Zyxel Prestige 600 series
List of user guides for Zyxel modems:
Jul 26, 2007 | Zyxel Prestige 841 (91-004-226010) Modem
Computers & Internet Logo
331 people viewed this question
David Payne
David Payne
