New compressor won't start
Copeland compressor wont start, getting proper voltage at top and bottom of contactor, new capacitor and hard start. ANY help out there?
2 Suggested Answers
SOURCE: new copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Posted on Apr 21, 2010
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
Need to know size of start capacitor for compressor fan start is 5
OK there are "start capacitors" & "run capacitors". I think you are after the run capacitor. A start capacitor KIT is only for the compressor. If you are after the capacitor that looks like the fans capacitor that can be tough. I've seen a lot of capacitors that are faded and can't be read. The only way is to get the compressor model number from the compressor its self. Usually on top of it but may be on the side. AND THE MAKER (Copeland, bristol...) Then you need to call some local parts houses (for a/c or refrigeration) and give them make & model # to see if they can get you the info. They probably won't sell the part to you but try. If its a Copeland compressor, the app store has an app called "xref" that is awsome. Has worked for me %95 of the time when I have had the same problem.
May 22, 2015 | Heating & Cooling
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
I have a 38ckc036750 A/C Unit and the fan run when the contactor closes but the compressor dont, the is a hard start capacitor that is across the run capacitor. what must I do to get the compressor going....
many technicians make the mistake of using a hard start kit instead of replacing a bad run capacitor, the problem is that it can be ******* the compressor, and the start capacitor can also go bad, you can start with removing the capacitors and replacing with a new run capacitor and see if that gets it running, also can try another start capacitor with the new run capacitor, some manufactures engineer there systems in that way, if not the compressor may be done. *Be sure to check all the electrical connections including those at the compressor under the terminal cover.
Aug 22, 2011 | Carrier 38CKC036 Air Conditioner
I changed out the capacitor in my outdoor AC unit and it still won't work. There is a slight humming noise and I can see the contactor pull in and out when the thermostat turns it on. Could my fan...
I would start by inspecting the contactor make sure you are getting full voltage thru it to your fan and compressor. Usually there is a capacitor for the fan and one for the compressor. Make sure they are getting proper power and that capacitors are good. check amp draw and go from there,
Jun 24, 2011 | Heating & Cooling
Compresor not coming on, have installed new hard start capacitor, only 1.2 volts at compressor
You must not have both sides of power going to the unit. I will try to tell you how that unit is wired. I don't know what kind of hard start kit you have. If it is just a two wire start capacitor kit, you need to connect it to "herm" and "C" on the capacitor.
"C" from compressor will go to the contactor
"R" from compressor will go to "C" on the capacitor
"S" form compressor will go to "herm" on capacitor
note: "R" on compressor will go to "C" on capacitor with a jumper wire from the capacitor to the other side of the contactor.
Jun 22, 2011 | Coleman Heating & Cooling
PHO24-IB GODDMAN CONTACTOR CLOSES, RUN CAPACITOR HAS CORRECT MFD, OHMED/MEGAOHMED COMPRESSOR...BUT IT STILL DOESN'T START.
I assume that is a 240 volt unit. If you have a volt meter, check for power across the contactor . If it is a 240 volt unit you should get 240volts on both sides of the contactor. If you DO have voltage across the contactor (after it closes) you need to try and get to the compressor where the wires connect to it. There should also be 240 volts at the compressor terminals marked "C" and "R". If you have power at the compressor between C and R and the compressor is still not even trying to start, the compressor windings are open. Here is really what any tech will need to know to really help you:
(1) Is the fan motor running?
(2) what voltage is the unit?
(3) is the compressor humming or trying to start?
(4) do you have the proper voltage at the unit?
If you can answer these questions and you want to email me, do so and I will step you thru it. Be very careful , as you are dealing with high voltage.
Apr 14, 2011 | Goodman HDC24WMC24 Air Conditioner
New copeland compressor wont start
Apr 21, 2010 | Heating & Cooling
Copleland scroll compressor failure
I have scroll chiller contains scroll compressor tandom circuit. One of the compressor failure from it due to unbalance of the winding. Previously compressor thermistor opens two to three times. Also one phase open in contactor of the compressor. Can you guide me regarding the reason of compressor failure and what is the next step for the replacement of compressor. Also give guide line for the points take care.
Nov 02, 2008 | Goodman Heating & Cooling
Copeland Comfort Alert diagnostics . code #8 welded contactor. new install trying to startup. ive seen this once before but cant remember what i did to fix. can you help.
All this means is that the Copeland monitor is sensing amp draw on the compressor but it is not detecting a Y signal calling for the compressor to run. If there is no problem with the contactor and equipment is running fine, check for the jumper wire that carries the Y signal over to the compressor monitor.
Jun 25, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
