Question about Cycling
How to use bell air attack 450 - Cycling
My son is 49 and has bells palsy several times what can be done and why does it reoccurr
Bell's Palsy is thought to be caused by the same hirpes virus that causes chickenpox, that antisocial infection of private areas, cold sores and shingles and inflammation causes mild nerve damage of the nerves controlling the facial muscles.
Recovery usually begins within 2 weeks of an attack but suffering 6 months is not unknown and there are isolated cases where an attack seems permanent.
It is possible to suffer from Bell's palsy more than once and like cold sores and that other thing this site won't allow me to name, attacks are probably more likely when the body is at a low ebb, run down, over-tired, weakened immune system...
You would probably find more information/discussion if you visit ehealth.com.
Jun 18, 2017 | Computers & Internet
My iron level is 1000 after taking prescribed supplements for a year. Is this dangerous?
That is way too high according to health experts. 450 is the high end, high iron levels in blood can cause heart attack risk to increase. The easiest way to lower it is to donate blood at a blood bank.
Oct 21, 2016 | Health & Beauty
My dishwasher Fagor fi-80 just fills continuously, till overflowing. How should it know its full? I cant see any sensors.
It uses an air bell to turn the depth of water into air pressure, then a pressure switch senses this pressure.
Down inside the wash tank, you'll see the air bell. Usually grey, a flattened rounded rectangle tapering wider towards its lower end, stuck to the side of the tank.
Take the panel off the machine, and on the dry side of the tank you'll see a little hose leading away from the bell towards the pressure switch.
Four of the more common failures....
1) Water valve stuck open. It'll keep filling even with the electricity turned off.
2) Air bell leaking. Crumbling plastic bits not unknown, this machine could be 15 years old by now.
3) Pressure switch stuck. Blowing into the switch you should hear a 'click'.
4) Most common - a build up of fat in the top of the air bell, blocking the sensing tube. With the machine empty of water, take the pipe off at the pressure switch end, and blow into it. This should dislodge any fat/debris. In extremis, slacken the nut holding the air bell to the tank, rotate the bell upright and give it a good wash out.
Mar 07, 2016 | Dishwashers
Belling Id 450 slimline has no power to buttons! Fuse is fine power supply is fine! No response from any buttons pressed....help!!!!
make sure that the connections in the motherboard are connected to your switch cables running to the front and that they are in the correct position.
Sep 02, 2014 | Computers & Internet
Can I bake at 450 degrees with a Blue Jean Chef covered casserole dish?
most items of this category are built to withstand 450 why dont you email the manufacturer or give their customer service a bell but I have used a lot of my stuff at this heat they should if they are any good take it but what are you cooking that needs such a high heat scones if so will be round for a nibble happy cooking
Oct 08, 2013 | Blue Jean Chef Home
My 04 crf 450 is leaking oil out of the air box breather
Hi, Jmattison21 and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Engine Oil leaking out of my CRF 450 air Box
Oil coming out of airbox 2012 CRF 450
Honda CRF450X 2005 Service Manual
OEM parts for Yamaha
Honda CRF450R Owner Manual
Dec 22, 2010 | 2004 Honda CRF 450 R
Cycling Logo
535 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
