Question about Kenmore 98702 Stacked Washer/Dryer
When machine if filling with cold water leaks out of the bottom of the maching
  • 1294 Answers
SOURCE: Water leaks out bottom of washer when filling
Open up the top of the machine after disconnecting the mains. Check the pipes coming from the inlet valve to the dispenser box. One of these must hv come off. Refix carefully.
And don't forget to rate me pl..............
Posted on May 31, 2008
ginko
  • 19396 Answers
SOURCE: 10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Posted on Dec 21, 2008
breddi2
  • 126 Answers
SOURCE: No warm or hot water
The easiest possibility is no hot water coming from supply,I have seen the valve turned off,input hose normaly has a filter where it attatches to the machine and they can get clogged.If neither of these solves problem just try hot valve to confirm water supply does work and if so more than likely the valve that hoses are connected to likely source of problem.
Posted on Apr 20, 2009
frederiquema
  • 76 Answers
SOURCE: water leaks at bottom of washing machine
Get the drun check out. It could be louse or it is totally of it's hinges.
Posted on Sep 13, 2009
  • 714 Answers
SOURCE: Cold water is not filling machine when place on cold washer cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Posted on Jan 11, 2010
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
The washing maching is leaking bottom right side.
Check the clamps that hold the rubber door boot in place. Also check your hot and cold water fill hoses to make sure they are tight.
Aug 03, 2011 | Kenmore HE2 Plus Front Load Washer
Machine whirlpool not filling whith water
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 15, 2011 | Whirlpool Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
My Frigidaire Galaxy Washing maching will not allow water into the tub.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 07, 2010 | Washing Machines
My machine doesnot fill water,as water start's and fill my drum it start leaking from somewhere, we checked water leaks from water pump. Last year we replace water pump. ya we change drain hose also.that...
The valve to the powder drawer is jammed. When you try to start the machine it trys to open and he water will try to pass through the valve. The water is at a constant pressure when the machine is off, but when you turn it on, it increases the presure and the water leaks. To the back of the maching, look at the blue hose, to the back of the washer, that should be sound, take the top off the machhing, two small screws at the back, follow the black hose from the cold inlet to the valve and I think you will find that is split/perished. I hope this helps, but if not let me know and I'll check o/l to find the fault for you.
Jul 16, 2009 | Washing Machines
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
