Question about Water Sport
Exhaust sensor yamaha waverunner
Exhaust indicator came on after ten minute ride time?
5 Suggested Answers
finish line
  • 207 Answers
SOURCE: Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
PWCYoda
  • 118 Answers
SOURCE: 2004 gp1300r jetski 20 mins riding and overheating
pull out the cat temp sensor and check to see if its bent. if so then its definently your catalist, even if not bent chances are still good it has failed. you need to be sure which light is coming on. does it look like a tube with squigly lines going up?
Posted on Mar 10, 2010
SOURCE: I have a 2003 yamaha 700 waverunner. It starts
sounds like the impeller is knackered, check the impeller housing and the impeller itself, impeller should look like its nearly touching the housing, check the housing to see if it has created a grove, if they both look worn, replace with new
Posted on Oct 07, 2011
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
1992 yamaha waverunner 111 wra650q Runs great until you shut it off or it shuts off? Ok as long as you restart in a few seconds it will fire instantly , if you wait 5 minutes or longer it will turn over...
Not real familiar with waverunners (this is a car and truck section after all), but remember that when you have been riding and stop engine it gets much hotter. Could possibly be coil "Heat Soak", or even a fuel system vapor lock issue caused by a pinhole leak in a line or a bad gas cap. Not very confident in this, but the best I got. Try posting in the waverunner section.
Jul 12, 2017 | Cars & Trucks
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
1995 Yamaha Waverunner III dies won't run
Check cylinder compressions, this ski will overheat if one side is low. Thus is step one, if ok and within 10% of each other, verify the exhaust isn't clogged with sand from "beaching" third verify the crank seals are not leaning the Mix causing an overheat. Obviously check the impeller housing to exhaust line isnt clogged, disconnecting the thermal sensor is asking for a top end rebuild which is about 500.00 they are designed to reduce revs and alternate spark to the cylinders once 200 degrees is reached.
Jul 31, 2012 | Water Sport
1996 Yamaha waverunner is not ejecting water on side port
Your 96 does not eject water from the side, it ejects water under the ride plate. There is no tell tail stream . You can add that or rely on the thermal sensor. But heed it's warning
Jul 08, 2012 | Yamaha 12V Air Pump
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
if u did any modifactions to the air intake than that could be a reason.
Jul 23, 2009 | Water Sport
1995 yamaha waverunner 3 exhaust leak
pull battery tray and find the broken hoses
Jun 23, 2009 | Yamaha FZ 600 Motorcycles
05 waverunner exaust ligth on what to look for?
your exhaust temp sensor is bad or broke it is located in the main exhaust under the seat on the right side of the exhuaust one wire going to it u cant miss it
Apr 14, 2009 | Yamaha 12V Air Pump
Water Sport Logo
44 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
