Somfy remote shows red light - Computers & Internet
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
TV will not switch on using the remote or manually on TV
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | LG 50PX1D 50 in. Plasma Television
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Hyundai dvd model hy-03s remote not functioning
first thing is the obvious, make sure you have brand new batteries installed. If you have a camcorder or digital camera, point it at the remote control and push record, while recording, press some of the buttons on the remote. the camera will record the red light if the remote is working (camcorders and digital cameras can see this light even though people can't) to do this with your digital camera, have somene push and hold one of the remote control buttons while you take a photo, the red ligth should show up in the photo. If you see no red light then you have a bad remote control and will need to send for one or get one ordered through the store, one other option is to buy a universal remote control and try getting that to work, good luck
Mar 16, 2011 | Hyundai Televison & Video
I miss placed my manual for my incredible holiday light show, The trees are all pluged in I get a flashing red light in the back but it wont start what am I forgetting to do
Just put mine up & it did the same thing. Unplug power. Have remote handy & paperclip. Find reset hole behind remote. Plug in power, red light will flash, hold reset button in until unit stops flashing. Make sure remote is also powered on. Thats it.
Nov 29, 2009 | Gemmy Toys
What does it mean when the light at the top of the remote is red instead of green?
The red indicates low battery. The batteries are estimated to last around 2 years at that point or later the battery will weaken and the red light will show up more often. In some rare cases the red light will not go away even with a fully charged new battery, in that case there may be something wrong with the charging circuit inside the remote that gives feedback on the battery's charge. You can either live with a false reading of the battery level and charge the remote nightly OR you can send it to RTI for a repair.
Nov 12, 2009 | Rti Technologies Rti T1 Remote Control
Awning motor just hums
I had the same problem with 2 Somfy motors within the same week.
The motor hummed and roared, but didn't turn. Sometimes, after it cooled down it started rotating, but stopped when the load started, Other times, would stat, but then changed the rotation direction and then stoped.
The awning company wanted to charge me ~ $600 for each new motor. They said Somfy does not fix motors, but only replaces them with new.
So, I opened the motor myself:
  1. I opened the 2 screws on each side of the tube's motor end.
  2. I pulled the plastic cover out with the plastic cogs assembly.
  3. I then pulled out the capacitor.
I noticed that the motor start capacitor "exploded". So, I bought a new one for $10, replaced it (no soldering is required), and assembled it back again.
The motor runs great now for less than 2% of the requested motor price.
Sep 29, 2009 | Drills
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
