Question about Motorola Mobility Tundra VA76r Cell Phone
Spring broke on flip - Motorola Mobility Tundra VA76r Cell Phone
  • Official Brand Answer
  • 3,100 Answers
Motorola no longer repairs this device model. Locate a local repair shop. They may be able to help fix your device as it is out of warranty.
Mark
Motorola Support
Posted on Jul 25, 2014
I was riding my arctic cat 580 ext efi 1995 .. When I hint a bump and the rear suspention dropped ... Flat ... How can I raze it back to where ther suspention is suppost to be at .. What happen . Why did...
It sounds like you either broke a suspension support, or the shock has collapsed. It could also be that you broke a spring. Most likely a suspension mounting point has broken. You are going to have to flip it on it's side so you can inspect the entire suspension mounting assembly. Without a full inspection it could be speculated all day and not come up with an answer.
Mar 08, 2015 | ATVs
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
Door will not stay closed
Sounds like the latch is seized or the tension spring is broke.
You'll probably have to replace the latch.
Jul 27, 2013 | Cars & Trucks
2000 VW Beetle drivers side seat adjusment cable broken?
Under the seat there is a spring that conects the 'handle'to the Latch, tha tholds the seat in place....you will have to look under the seat to see if the spring is broke
Nov 07, 2011 | Cars & Trucks
The door flips down for loading. The cables
bottom interior part of the dryer has two small holes the spring attatches to
Aug 17, 2009 | Kenmore Dryers
The flip on my daughters Sony Ericsson W350 broke and I can't seem to be able to find out how to replace it. Any ideas?
try going to the store. If you pay for insurance, they'll send you it within 2-3 business days (mine broke, too!)
Aug 13, 2009 | Cell Phones
My kenmore 80 series washer went to the spin cycle then made a loud noise like maybe a belt is slipping around? its a loud vibration the water will still drain but will not agitate or spin. However, it...
no belt,it is direct drive(use a coupler)yours is broke,remove the 2 head screws one on each side,flip up disconnect the wire jack,pop the 2 spring clips out one on each side,tilt the cabinet toward you and pull it off,remove the 2 water pump spring clips,pull pumpoff,remove the 2 motor spring clips and the motor will fall off into yours hands,now you can see how the coupler goes on,you can get a coupler from your local appiance part store for $5,let me know how you make out-mike
Mar 21, 2009 | Kenmore Washing Machines
Motorola A1200 Flip Damaged
Your in luck! www.cnn.cn you can get full housings and replacement hinge springs for this model phone. Im not sure which parts exactly are broken on yours, but you can get any of the case pieces from that web site. I personally have ordered from there before and have been satisfied.
As far as the repair manual, no, there are none available to consumers that im aware of.
Need anymore help let me know!
Jan 13, 2008 | Motorola Mobility MOTOMING A1200...
The cover of detergent dispenser does not open..
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Motorola Mobility Tundra VA76r Cell Phone Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
