Question about Toshiba SD-V392 DVD Player/VCR
Sylvania tv mts/sap dvd player/vcr
Dvd is stuck and wont eject
  • 59 Answers
SOURCE: DVD stuck in DVD player will not eject
I just fixed one of this exact model SD-V392SU with same problem. This takes a bit of manual dexterity, but it can be done with some care and patience.
THE PROBLEM:
There is a small plastic nylon gear on the shaft of a miniature motor in the DVD mechanism. This gear is likely floating loose in the machine. It is what connects the motor's shaft to the rest of the mechanism to operate all it's functions which include opening and closing the tray and raising and lowering the laser and spindle motor that spins the disks. Be careful not to lose it once the lid is removed from the unit. It is quite small.
Unplug the unit and use a well lit area to work in such as the kitchen table covered with a large towel to protect the unit and the table.
There are 5 Philips head screws holding the lid on. One each side and 3 in the back. Remove those paying attention to where they come from. There is a subtle difference in the lengths of the screws. I use empty prescription bottles to keep things sorted when I work.
The lid can be removed by sliding it slightly backwards and tilting the rear of the cover upwards and back. Once the lid is off the unit, you must locate the small white nylon gear that has come off the shaft of the miniature motor that drives the mechanism. A good tip is to lay out a dark colored large towel to shake and dump the loose gear out and onto so you can more easily see it's white color.
REMOVING THE DVD MECHANISM:
There are 2 flat ribbon connectors and one 3pin mini molex connector connecting the DVD mechanism to the main board of the unit. Grasp the cables as close to the connector as you can get.and gently disconnect these by carefully pulling them out. All three are different, so you can't mix them up to put them back.
There are four screws holding the black plastic mechanism in the unit. One long shoulder style screw at the rear center of the mechanism, and three short screws with captive washers. Two of the three short ones are located one on each side of the mechanism towards the front face of the unit and one near the right hand side about three quarters of the way to the rear of the mechanism. A magnetized Number 2 Philips is the best tool for removing and replacing these screws as the two short front screws must be removed from rather tight quarters in the recesses of the unit. The magnet holds the screws on the tip so you can raise and lower them into position while removing and replacing them.
Once the three connectors and four screws are removed, you can lift the rear of the mechanism slightly and tilt the mechanism out of the unit. Once again, keep a sharp eye out for the loose little white gear.
Now that you have the mechanism out of the unit, you can manually eject the captive DVD.
First a little about how this mechanism works.
Look at the front face of the mechanism. You will see a white actuator bar that slides left and right. This is what raises and lowers the laser/spindle assembly. When the mechanism motor spins, connecting gears move this bar raising the laser/spindle motor assembly up. This causes the disk to be clamped against the top of the drive in play mode so the spindle motor can rotate the disk for the laser to read, The disk tray is basically locked when in this position and it can not slide out to give you the disk.
With the gear missing from the mechanism's motor, it will be possible to move that white actuator bar that raises and lowers the laser/spindle motor assembly. Note that there is a switch with three wires on it located on about front face center that is operated by that white bar. This switch tells the mechanism motor when it is loaded and unloaded so the motor knows when to stop spinning as it loads and unloads. Once the bar lowers the laser/spindle, the tray should be able to be coaxed out. Looking at the bottom of the mechanism, you may be able to spot the gear so you can assist the mechanism's white actuator bar, but with the motor's gear missing, the other gears can spin freely.
Once you have your disk out and you have found that little white gear, you can begin the actual repair of the mechanism.
Looking at the bottom of the mechanism, you can see the bottom of the motor the little white gear came off of. This is NOT the spindle motor that spins your DVD's Once you know where that motor is, you can imagine where the shaft of it will appear on the top. Viewing the top of the mechanism, there is a combination of gears that that little gear drives and you should be able to find the motors bare shaft pointing up. This, of course, is where that little white gear belongs.
Now there is two ways to put the gear back on the shaft. I removed the two other gears this one meshes with so I had a little more wiggle room. The other way, of course is to leave the other gears in the way. This makes replacing the small gear more difficult as there is less room for error in placing the gear.
The gear closest to the front of the mechanism has a plastic hook that can be very slightly moved aside to allow that gear to come off it's shaft. Note the difference between the top and bottom of these gears so you know which way they go back on. Once the one with the hook holding it on is off, the other one can just slide off it's axle as it is held in place by the first gear you took off.
I used some Q-tips and alcohol to clean the shaft of the motor and the inside center of the little gear. Then I used a poor man's bearing mount (clear nail polish) and a plastic tooth flossing tool to apply a very thin coating to the inside of the gear and a Q-tip for coating the outside of the shaft to help keep the gear from coming off again. This must be very carefully applied as you don't want any excess nail polish running down the shaft of the motor and getting in the bearings of the motor. There is a special fluid called bearing mount for fixing pulleys and gears on shafts, but I didn't have any of it or the commercially available thread lock. Bearing mount is basically just very thin, watery thread lock like fluid.
I used the small pick end of the tooth flossing tool to position the gear over the motor's shaft and then pressed it back on using a small screwdriver. The gear is very light, so the tackiness of the nail polish was enough to hold it to the tooth pick's curved pick end. Give the nail polish at least an hour to dry before attempting to move the mechanism. Now that the gear is in place, things can't free wheel any more and you don't want to stress the gear before the polish has had a chance to dry.
Once the gear is pressed back on the shaft of the motor, you put the other two gears back where they came from and it's ready to go back in the unit.
Tilt the front of the mechanism down slightly as you slip it back into position. Note that the back end of the mechanism has a small recess where the rear supporting post fits into. All the holes for the screws should be lined up before you start putting them back in. A good tip is that I always turn the screw counterclockwise or reverse after placing it in the hole and wait for it to thump or click down again before turning it clockwise in. That way I know the screw is seating properly and won't cross thread. It turns back in very easily or I reverse again.
Hold the ribbon cables as close to the end as you can as you put them back in their sockets. There is a small amount of reinforcement near the ends of the ribbons to assist in plugging them back in. Otherwise, it's like shooting pool with a rope. :o)
Replace the lid with the rear of it tilted up and slide the front under the face of the front bezel. Everything should fit nicely and the screw holes should all line up. If it doesn't, you've got it wrong, try again.
That's about it. I hope this helps.
Posted on Feb 22, 2009
  • 31 Answers
SOURCE: dvd/vcr player
sometimes this is openend by a small rubber belt or a worm mechanism driven by a rubber belt,take off top and see if belt is slipping,
Posted on Jul 19, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: I tried to eject a DVD and now the DVD holder is
if you had forced it open its probably not aligned (if its still open give it a little shove and press the eject again (otherwise unplug the machine for 5-10 min..and try pressing the eject button again
Posted on Jul 09, 2010
  • 39 Answers
SOURCE: My Toshiba VCR & DVD video recorder model
A temporary solution would be to use a paperclip to eject it; usually, any disk drive has a little hole that a paperclip can be stuck into which forces it to eject.
Posted on Mar 04, 2011
islandmyth
  • 120 Answers
SOURCE: cant open dvd door:
You can force a dvd player to open. If you noticed there's a small hole in your dvd player as big as a paper clip. All you need to do is to find a paper clip and use it as a key to open ur dvd player.
Posted on Mar 19, 2011
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
Sylvania MTS/SAP TV. I don't have a remote I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver...
I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver (either through input jacks on front or on rear. Menu gives various options, but none of them gets me back to being able to see the picture.
Apr 07, 2010 | Sylvania SRT2232S 32" TV
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Hello, My vcr tape will not eject and it was working fine an hour ago. Do you know what the problem is?
Have looked through the manual Sylvania DVC-800C DVD Player / VCR Combo and there is no mention of a tape not ejecting. if its under warranty give the dealer a ring. If dvd`s stick and nothing more can be done then have tried the belo. http://www.ehow.com/how_2036282_remove-dvd-player.html
Oct 18, 2009 | Sylvania DVC-800C DVD Player / VCR Combo
Problems playing a VCR tape
check/replace your vcr's belts, clean the reel sensors and check or look for bloated and deffective capacitors on power supply section,
Oct 13, 2009 | Sylvania SSD803 DVD Player/VCR
Is my tv digital ready?
If you have cable or satelite hooked up to it now and it works,Then it is digital ready.
Please rate this a fixya
Feb 13, 2009 | A D S TV Superscan 2 (SFN-201)
Toshiba SD-V392 DVD Player/VCR Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
