Question about Denon AVR 3808Ci Receiver
Can I connect I phone 5 to the Denon AVR 3808CI and Lawson to music? If yes. How?
robotek
  • 1512 Answers
SOURCE: What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Posted on Mar 16, 2008
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
Duncan
  • 218 Answers
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Posted on Nov 28, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
RC-1068 preset codes
My self have problem with Denon AVR 3808Ci Receiver, the HDMI is doesnt work anymore, and I can not find replacement parts because receivers is out of date, very shame
Mar 30, 2014 | Denon AVR 3808Ci Receiver
I have a denon avr 3808ci and all of a suden im not getting sound frome sub.?
I'm having the same problem. Changed the wire from LFE to LFE input to the sub... I have a velodyne which has always worked great. Connected the sub with the original wire to my sony amp and it works great so it's the output on the amp. Any suggestions
Dec 08, 2012 | Denon AVR 3808Ci Receiver
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
How do I configure my denon avr3808ci to play 7:1
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
First, you must have all 7 primary speakers plus a powered suboofer attached. Page 9
Page 25 describes how automatic detection and adjustment is achieved. Page 28 for manual speaker setup.
Assign digital inputs. Page 39.
Then feed it appropriate 7.1-compatible material. page 40
Feb 28, 2011 | Denon AVR 3808Ci Receiver
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
I cant turn off the closed caption on my avr-3808ci...???
The receiver has nothing to do with that since it doesn't actually tune the station or decode the video content.
Usually, it's the TV that deals with CC.
Feb 09, 2011 | Denon AVR 3808Ci Receiver
I need a Denon AVR-3808 Service Manual
try doing a google search for avr 3808 manual
also try going to denon.com if you need a hardcopy call denon tell them to send you one.
Feb 18, 2010 | Denon AVR 3808Ci Receiver
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
How do I set up outdoor speakers? I currently have them set on Surround B, but do not seem to be able to play them
Fined in owner's manual section about MULTI ZONE CONNECTION AND OPERATION. page 68. If you don't have a manual, download it from here : http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf
Nov 08, 2009 | Denon AVR 3808Ci Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Denon AVR 3808Ci Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
