Question about Haier HLP140E Electric Portable Dryer
Removing back How to remove back to change belt
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Do you remove belt when removing alternator
Hi:
To remove the belt, you must loosen the belt tensioner pretty far.
It is located up near the front of the engine, not far from the air conditioning compressor. It has a 10mm bolt that must be loosened, and that will allow the belt to be removed. After the Alternator is replaced, tighten the belt back up, and start the car , shut it back down and adjust the belt as needed.
Mar 22, 2014 | 1998 Honda Civic
How do I Change the alternator belt on my mazda?
IF IT IS ON THE OUTSIDE OF THE OTHER BELTS, ALL YOU HAVE TO DO IS UNBOLT THE TOP OF THE ALTERNATOR, AND PUSH IT IN TO LOOSEN THE BELT FOR REMOVAL! IF IT IS IN BACK OF THE BELTS (ESPECIALLY A SERPENTINE BELT) YOU'LL HAVE TO REMOVE THE SERPENTINE BELT FIRST! THERE WILL BE A TENSION PULLEY HOLDING THE BELT TIGHT! YOU'LL NEED TO USE A WRENCH TO PULL THE TENSION PULLEY TOWARD YOU TO LOOSEN BELT! WATCH HOW YOU REMOVE IT, BCUS YOU'LL NEED TO PUT IT BACK ON THE SAME WAY! THEN REMOVE, AND REPLACE THE ALTERNATOR BELT AS BEFORE, THEN REPLACE THE SERPENTINE BELT!
Mar 05, 2011 | Mazda Protege Cars & Trucks
How to change land rover freelander fan belt
You have to jack it up and remove the underboady engine cover. Lower the vehcile and open the hood remove the engine cover. Use the jack to support the engine for underneath. you'll need to remove or swing the top passenger side engine mount. back off the tensioner from the belt. Auto Zone, Advanced Auto rents a tool if needed. Now you can change your belt!
Dec 29, 2010 | 2002 Land Rover Freelander
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
How to change belts
1.) slacken alternator bolts..
2.) pus alternator forward,,
3.) remove that belt (TAKE NOTE WHERE IT GOES)
4.) slacken compressor or power steering pump,,
5.) push forward,, remove that belt (TAKE NOTE WHERE IT GOES)
6.) replace bolt belts and tighten back slackened components,,, use a bar to pry the alternator (power steering or compressor ) back to create tension on the belt before you tighten back the bolts..
PS TAKE CAREFUL NOTE THE POSITION YOU REMOVE THE BELT FROM AND REPLACE NEW ONE ACCORDINGLY!!
Mar 12, 2010 | 1991 Nissan Maxima
How do I replace the Timing Belt on my '91 Geo Prizm?
Remove all nessary parts to access cover. Remove cover. Line up the timing makrs before removing old belt if car is still in running condition. Loosen the belt tensioner and remove belt. Install in reverse order making sure to load tension back on belt at the tensioner.
Mar 05, 2010 | 1990 Geo Prizm
How do i change a fan belt on a 1994 pontiac grand am v-6
To remove the belt, put a 1/2" drive breaker bar into the receiver on the tensioner and push the bar so it moves the tensioner counter clockwise. Remove the belt and put the new one back on following the diagram on the sticker on the car. If no sticker, before removal, draw yourself one. When putting the belt back on, get everything positioned correctly and again push the bar in the same direction as you did to remove and put the belt back on the tensioner pulley. Check that all pulleys are engaged with the belt properly, start the car and watch the belt for a few minutes checking that no pulleys are wobbling etc. and that belt is running true.
Sep 06, 2009 | 1994 Pontiac Grand Am
How do i change the alternator for ae100
first remove the batttery connections. second remove the belt that goes around it either by the tensioner if serpentine or if v-belt. the alternator i think on that car is underneath the passenger side of the wheel well. remove if there the dust cover. there is 2 bolts that hold it on the mount less than 6 inches apart ( top and botton) remove the positive connection and the plug. to put back on reverse the procedure.
Thanks.
Jul 01, 2009 | 1992 Toyota Corolla
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Haier HLP140E Electric Portable Dryer Logo
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
