Question about Nespresso Citizmilk D120
Can't adjust volume of coffee - Nespresso Citizmilk D120
How to adjustment to bunn coffee maker s series?
What do you want to adjust? Pour time/volume, temperature???
Jul 17, 2014 | Bunn Coffee Makers & Espresso Machines
Grind size cannot be ajusted
On the side of the machine is a rotary dial, this adjusts the grind size. The other dial adjuster only increases or decreases the volume not the grind size.
Oct 20, 2010 | Breville Fresca BES860 2Cup Coffee Maker
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Oct 12, 2010 | Bunn Dual SH DBC
How do I adjust the volume for each cup of coffee
Hi
Push and hold the coffee button you want to program. Do not release this button. It will grind, click 3 times, the the brew unit will cycle up and start to dispense water. When you get the amount of coffee you want for this button, then release the button and its programed. If the button is held more than 3 seconds, it will reset to zero water. Reprogram again.
Jun 11, 2010 | Saeco Incanto Classic Espresso Machine
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Jul 14, 2009 | Bunn CWTF35-3- Stainless Steel
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Aug 10, 2007 | Philips Senseo HD-7810 Coffee Maker
Nespresso Citizmilk D120 Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
