Kyocera Copystar CS-1635 Copier
Problem for Kyocera Copystar CS-1635 Copier
Setting up a copier to use
By shadow_schtt on Jun 19, 2009
When seting up a copystar cs 1635 i can't figure out how to select "d-L". that's the only thing i have to do
Solution #1
posted on Jun 22, 2009
Not Rated)
ncruz_08
Rank: Guide
Rating: 75%, 2 votes
hi if enter simulation 1087 1087 and select 000 inmidiatly appear d-l and press enter
after to out do you enter with arrow up and down the number 1 in the display and press enter
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1635
Questions and Unsolved Problems for Kyocera Copystar CS-1635
Do you recommend Kyocera Copystar CS-1635 Copier?
Answer
Answer
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is... (More)
Answer
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this... (More)
Answer
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black... (More)
Answer
canon ir 1630 copier system erroe E245
Answer
HP c4280 Photsmart paper feed causing jam. Pulling on right side.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Copystar CS-1635...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
