Question about Whalen Firepit 28" Black Designer Series Heater
Cant get the heat to blow out
Model number FP30-2A
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
Not heating
There are a few things that can cause the dryer to not heat there is a one time thermal fuse that can blow causing the heating element to not function . one cause of this thermal fuse to blow (in this case heat) would be the lint in the dryer vent tube it clogs the tube then the heat builds up by the heating element and blows the resistor this is very common . One other problem that can occur is the heating element could get burnt out and short out .after some years of use the wire come out of its normal shape and move around and eventually touch the side of the metal housing causing the element to open or break. you can check out this site www.repairclinic.com and put in your model number and find the thermal fuse kit should cost around 22$ the heating element can be from 60 -180$ depending on what type of dryer you have
Nov 24, 2012 | Whirlpool Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
The fan works but its not blowing any heat
what's the brand name and model number and what fan are you talking about?the convection fan?if so the element is probably bad,the element heats up and the fan just blows the hot air off of the element
Nov 27, 2011 | Kitchen Ranges
M rear heat in my03 envoy blows cold air
There is a service bulletin for poor rear heat on these models.The bulletin number is 05-01-37-002A.The part numbers are 89024885 for 4.2 engine and 89024886 for the v8 engine.It is an auxiliary pump the helps the coolant flow to the rear.The a/c system has to be recovered so I don`t think you can do this at home unless you have an a/c recovery machine.Hope this helps.Good luck.
Feb 22, 2010 | GMC Envoy Cars & Trucks
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Running and blowing air but not heating
It would help to have a model number. But before you send one make sure you turn off the breaker to the dryer all the way off then turn it back on and see if it starts heating. If that does not work write back with your model number.
May 12, 2009 | Dryers
Mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Mar 09, 2009 | Heating & Cooling
NOT BLOWING WARM AIR
Most dryers have a thermal cutout, a non-resettable overheat protection, take the model and manufacturer details to your local repair store and you can buy one easily.
then its, take off the rear plate, and trace the exhaust air ducts back till you find an identical item screwed to a duct, unplug its connectors screw the new one in place, plug in the connectors.
Exact info cant be given as you did not tell what make and model the affected dryer is
May 18, 2008 | Dryers
Heating & Cooling Logo
Top Whalen Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Whalen Heating and Cooling Expert? Answer questions, earn points and help others
