Question about GE JVM1790 1000 Watts Convection / Microwave Oven
GE profile JVM1790 blew bulb and fan will not turn off when door is closed
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
IFIXALL
  • 868 Answers
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Posted on Sep 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: interior light staying on in GE JVM1790 and
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Posted on Jun 08, 2009
  • 78 Answers
SOURCE: I have a GE jvm1790 microwave that when its pluged
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Posted on Nov 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: GE Profile Convection/Mircowave Oven Hood
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the door switch that has gone bad and should be replaced as everything else is working fine so don’t think its fuse or anything else that has gone bad. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Sep 02, 2010
GE Profile microwave PVM1790 starts, what I believe is an internal fan, when I open the door. I sure hope it's not the microwave component frying me.
You probably have a defective door switch, or a bad relay. You are not being microwaved. It would blow its internal fuse to prevent that from happening.
Jan 16, 2017 | GE Microwave Ovens
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
GE Profile convection JVM1790 will not heat. Everything else works but not heating. The oven is only two years olds. Any suggestions?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 16, 2011 | GE JVM1790 Convection / Microwave Oven
My ge Profile microwave convection oven (JVM1790) will not turn off. I don't think it is actually heating and the turntable isn't turning. However the light is on and it sounds as though it is heating...
sounds like the broken latch is your problem.yes you can buy a latch assembly and fit .broken latch does not activate micro switch so it is like having the door open.hope this helped you let me know
Jun 22, 2010 | GE Profile Spacemaker Over-the-Range...
Interior light staying on in GE JVM1790 and
Jun 06, 2009 | GE JVM1790 Convection / Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
GE JVM1790 1000 Watts Convection / Microwave Oven Logo
24 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
