Question about John Deere 50 60 70 520 620 720 Power Steering Plate
Model 60 transmission repair
Repair transmission gears pto slider gear
How do gears to drive pto go in the manual transmission
If your transmission is PTO ready, there will be a plate on the side of the tans where the PTO bolts to it. The PTO will have a gear that goes into the transmission that is driven off of a gear on the input shaft. You will be able to engage and disengage the PTO by a slip gear in the PTO itself.
Nov 24, 2015 | Cars & Trucks
Pops out of 4wd and pto not working and dif. lock not working
PDF]PTO Popping Out of Gear, How to Fix - N Tractor Club
www.ntractorclub.com/howtos/pdfs/PTO-Popping-Out-of-Gear.pdf
PTO Popping Out of Gear, How to Fix ... If your PTO shift lever does not stay engaged, the problem is probably not in the PTO transmission, but rather is due to ...Missing: 4wd
Oct 20, 2015 | Cars & Trucks
Why will the PTO pop out of gear especially when traveling down hill?
A manual transmission jumping out of gear is a sign of excessive gear lash. Your transmission bearings need to be replaced before the gears are damaged. This is a BIG job.
Jun 05, 2014 | Ford 8N Tractor
PTO stay engaged on allison transmission md3060/ PTO chelsea 277
wires to the pto solenoid incorrect and not wired properly through the switch
did you put the correct shims under the flange of the pto mount as it it is incorrect distance , the pto teeth will say jammed in the transmission gear teeth
suggest that you take it to a shop that fits pto and have the installation checked before you damage the transmission
Mar 12, 2013 | Garden
Whenever you down shift into first gear it clicks like a macjine gun going off. If you wait till you stop it will go right in to first gear. What is the diagnosis? What is the approximate repair cost?
This sounds like a slightly bent shift fork. The slider gear dogs are clicking on the face edge of the gear you are shifting into. If the fork were not bent, the slider would push the slider gear further and engage more fully. The repair is major surgery on the engine. I would take the bike to a dealer to confirm my diagnosis and at the same time get a cost estimate. If you get out for under $1000 dollars you will have lucked out. Please rate my answer. Thanks.
Aug 23, 2010 | kawasaki VN 1500 Vulcan Classic Tourer...
Gearbox continually jumping out of gear.
If this is a Manual transmission and if you push hard and a shifter it still pops out your shifter may be out of adjustment. The other possibility is the synchro teeth on the gear are in a slider rings are worn in the transmission needs to be rebuilt. Good luck.
Jun 04, 2010 | 2000 Toyota Land Cruiser
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Wont shif into 2nd gear grinds
Normally the problem would be a bent shift fork and that may indeed be the problem. The shift fork is a part of the gearbox and works by sliding a gear with "dogs", (pins), left and right on a shaft so that it engages with another gear. If a fork gets bent it will travel left & right as normal but since the slider gear is out of position due to the bend the gears don't mesh properly, i.e. the slider gear doesnt quite reach far enough into 2nd gear for the two gears to mesh fully. This is not a repair for the novice.
Mar 09, 2009 | 1985 Yamaha XJ 700 X Maxim
John Deere 50 60 70 520 620 720 Power Steering Plate Logo
21 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
