Question about Minolta Di251 All-In-One Printer
Stop Lines On Page
When I print or copy i get lines going accross tha page. I tried cleaning som things but it didn't help.
  • asomervil632 Jun 19, 2009
    That didn't help, It's happening when I print, so I know it isn't the glass. The lines are in the exact same spot on every page.
    Guru:
  • 830 Answers
Hi. This can be caused by the scanner glass being dirty. Lift the scanner lid and gently clean with newspaper and glass cleaner. Be sure and clean the hidden areas that you cannot see very well. if this doesn't solve the issue, then take the ink out and shake gently left, right up and down back and forth. It may be that the ink has blemishes or is old.
Posted on Jun 19, 2009
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Jun 19, 2009
    When you print, it runs thru the scanner, which creates the lines. The glass that is hidden (when you put a peice of paper to copy) is the one that needs cleaned. This can be a little difficult to find, I literally had to take half the printer apart one time.
My bizhub c451 suddenly started printing and copying nothing but colourful dots and lines all over the page. even with a test page i can only see a windows logo and all dots and lines, no text. even
Make sure the ink cartridge is full or new. Get to the "Maintenance" page and try an alinement. (The ink dries and will clog the jets if not used often enough.)
Jan 01, 2015 | Konica Minolta Bizhub C451...
Just got new Konica Minolta C224 copier. Prints from computer are perfect but when I try to copy something in color it prints page with thin even cyan or magenta lines. Lines are spaced evenly about 15 mm...
MAKE SURE YOU DO EXACTLY WHAT THE INSTALLATION MANUAL SAYES, INCLUDING DOING THE"Performing Non-Image Area Erase Check" I KNOW ITS A PAIN, BUT IF YOU DONT, YOU SEE WHAT HAPPENS
Aug 24, 2013 | Konica Minolta Bizhub C224 Color Copier /...
Blank lines through my text or graphics several times per page...help!
Here's the starting point for any print quality issues. The subject starts pretty broad, but if you follow the instructions, you should be able to solve your problem.
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
When printing some print missing, blank lines accross page.
1. Take both ink cartridges out.
2. Wait for 10 seconds.
3. Put them back in.
4. Go to Maintenance (Printer Conrol Panel or ? Help on your Home /Center software) and clean printhead.
5. Try printing.
NOTE: If issue still persists, pls contact kodak for printhead replacement.
Best Of Luck
Nov 18, 2009 | Kodak Office Equipment & Supplies
I have red lines that go accross the the page. It is inconsistent. Sometimes just the top Qt other time the whole page. Tried nozzel cleaning and new ink.
It is caused by waste ink at bottom plate of head. Print blank pages for cleaning itself. You can clean it by put wet tissue at bottom side of head. Turn off printer, move head to center. Put wet tissue at pad. Move head to parking position. Wait for 15 minutes. Print blank pages for checking.
Jul 18, 2009 | Epson Office Equipment & Supplies
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
Lines going thru the pages of fax i send
you ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Dec 13, 2008 | Dell 1815dn All-In-One Laser Printer
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Black lines through documents
Try cleaning the cartridges to see if that helps..... mine did the same thing and after I cleaned it, it worked like new.
Feb 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
Minolta Di251 All-In-One Printer Logo
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
