Question about Miele T9800 Electric Dryer
Door latch stuck open - Miele T9800 Electric Dryer
Drivers side door closed and will not open.
Remove inner door latch and try operating the rod manually (vice grips). If locked, spray everything inside the door with WD-40 or the like and try operating the lock.
Aug 15, 2016 | 2011 Honda Fit Sport
Trunk latch is stuck, door will not close toyota matrix 2003
try putting a screwdriver in latch while opening with the handle you might have hit it and closed latch when door was open
Feb 18, 2015 | 2003 Toyota Matrix
Rear latch lock stuck in the open position
use a round bar ( a screw driver ) and place it under the latch and pull the latch out as you press the button to unlock as if you were opening the door.
Jan 06, 2014 | 2008 Chevrolet Uplander
Door latch stuck
Bend down on one knee and use one hand to hold the exterior door handle in the open position while using a screw driver to disengage the door latch by inserting the screw driver's tip into the anchor hole and push the screw driver outward towards the car.
Dec 22, 2013 | Cars & Trucks
2012 Passat - Front driver door will not latch
It sounds like the latch is stuck closed, Not allowing it to go over the pin that the door latches on. If it is stuck closed open the door handle and use a screwdriver or something to open the latchThey started putting plastic on the latches on cars to make them quieter, the plastic starts to wear and causes the latch to stick.
Dec 13, 2017 | 2012 Volkswagen Passat
My 91 chevy truck is stuck open
SOUNDS LIKE LATCH WAS IN CLOSED POSITION WHEN DOOR WAS SHUT I'VE HAD IT HAPPEN A FEW TIMES PUT A SCREWDRIVER IN THE LATCH OPENING AND PRY WHILE PULLING INSIDE HANDLE...IT MAKE TAKE A TIME OR TWO
Oct 11, 2012 | Chevrolet Cars & Trucks
Door stuck cant open latch
Your latch mechanism in between door and door frame is stuck. Need re-greasing or a new latch.
Feb 03, 2010 | 2006 Saturn Vue
The door is stuck. The latch will not release.
If you look carefully near/under the latch, you will probably see some screws that holds the latch handle on. As you remove those screws, it will probably be obvious how to get the door open.
If you post the manufacturer and model number back here, I can be more helpful. OK?
Aug 05, 2009 | Maytag Dishwashers
Dishwasher door latch
Its very east to open. Take the top cover plate off the appliance, undoing the screws at tha back and it will reveal the latch.
regards
george
Mar 30, 2008 | Dishwashers
Stuck door latch
no call a tech micro-waves can be dangerous to work on
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Miele T9800 Electric Dryer Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
