Question about Samsung 26 Cu Ft French Door Bottom Freezer White Refrigerator - RF263BEAEWW
Samsung RF263BEAE ice maker freezes up
Ice inside the ice maker tray slightly melts then freezes together and jams the ice maker
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
SOURCE: Samsung RS2555SL Ice Maker gone nutty!
The icemaker relies on the motor to twist the ice tray about 120 degrees or so the dump the ice out of the tray. In order to get the ice to separate from the tray the force of the motor actually torques the tray against the rear plastic support (much like you would twist an old fashioned ice tray that you fill up by hand). Anyway, this puts a lot of force on the plastic elements that support the tray and they break after time. Once the plastic support breaks in the back there is nothing to get the ice out of the tray and each subsequent filling of the ice tray results in water spilling all over the ice bin and eventually leaking out the front of the refrigerator. You can order the part and fix it yourself (the part is DA61-00244A and is available from a number of websites. Total cost about $16 with shipping.
Posted on Nov 04, 2009
  • 146 Answers
SOURCE: I have a samsung rfg297aars refrig. I believe the
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Posted on Jan 19, 2011
SOURCE: The ice maker in my samsung fridge is putting too
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray is supposed to catch the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Posted on Feb 05, 2011
SOURCE: My samsung rf265abwp ice maker is over filling the ice tray, the wiring harness is hanging down, I don't know where it attatches and I suspect this is what is causing the ice maker to malfunction caus
I have the same problem, has anyone figured out how to fix it?
Posted on Jan 06, 2013
The top ice maker freezes up and the ice cubes don't dump
The heater in the ice tray is not going on to slightly melt the cubes so they can be pushed out of the tray. Either the element is burned out or it not receiving power. If it is the element you may have to replace the whole shebang since I have not seen the tray assembly sold separately. But I have seen brand new ice makers for about 45 dollars on ebay so ....................
Feb 29, 2016 | Refrigerators
Ice maker fills and freezes won't dump ice. It will if I hit the test button but not on its own
It sounds like it may be a bad freeze sensor. Consider having it services.
HOWEVER
The first thing I would recommend is removing the necessary grills and clean the condenser area and be sure the fan is operating. This becomes a problem in clean homes because the dirt slides on the floor and into the condenser coil where as the dirt sticks to a dirty floor.
Jun 20, 2015 | Samsung RF260BEAEWW 25.5 cu. ft. French...
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The ice maker in my samsung fridge is putting too much water into the ice tray thus dripping water into the ice compartment and freezing all the ice cubes together and dripping through the outlet
Good luck,
Vlad
Jul 17, 2010 | Samsung RS2578BB Side by Side Refrigerator
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Ice maker doesn't work
try as little bit harder and the ice maker should pull out stright from the freezer. watch out for the holders they are on the back and they sometimes are broken if you are not carefull with them. there is also two wire that have to be unconected when you do this. they are moilex connectors and if you push the tabs they should pull apart real easily. Thanks for using FixYa And have a great new year.
Sep 09, 2008 | Samsung RS2578BB Side by Side Refrigerator
Oct 20, 2006 | Samsung RS2578BB Side by Side Refrigerator
Samsung 26 Cu Ft French Door Bottom Freezer White Refrigerator - RF263BEAEWW Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
