Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice will taste musty but the water tast fine
When the ice melts in the cup of water the water taste musty and we have the new filter on the fridge
rylee_smith
  • 8619 Answers
SOURCE: Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Posted on Feb 11, 2009
  • 744 Answers
SOURCE: Terrible taste that came from water?...
Do you have a water softener? It's possible the softener was in soak when you used the water dispenser. That would explain the "salty" (hi sodium) water taste and thena retrun to normal later.
Also, if you get your water from a muncipal well, they may have been experiencing a problem at the time with higher than normal sodium content.
Posted on Apr 08, 2009
  • 503 Answers
SOURCE: bad tasting ice from the ice maker
I honestly don't know anything about these freezers but if your ice is that bad then i would suggest one of two things is going on
1- the supply line is causing a problem, to close to something that is heating it up or else
2- The filter in the fridge might need changing since it's possible something got into it.
That's about the only suggestions i have for this problem. Hope this helps
Posted on May 23, 2010
honeymokey
  • 3113 Answers
SOURCE: My new Whirlpool Refrigerator the water and ice still stink
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Posted on Oct 30, 2010
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Posted on Dec 07, 2010
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Sub Zero 650S with bottom freezer-Ice tastes funny(musty ? taste)
The 650 does not have a filter built into the unit. Any filter would be on the supply line to unit, usually in the basement below the unit, or under the kitchen sink. Do you use alot of ice? If not you may want to empty the bucket every few weeks to let it produce fresh ice.
Jul 21, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Jan 04, 2009 | Jenn-Air JCB2388G Side by Side...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
15 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
