Question about Canon PIXMA MP600 all-In-One InkJet Printer
Pixma 610 printer not printing any ink, copying is the same, Paper feeding through like normal helppp
  • 4 Answers
I know this is a stupid question but....are you out of ink? if so, you know what you have to do. If not, it could be a few different things. Ink cartridges may be bad/dried out, or the print heads may be clogged. Those are the most likely problems. Your printer should have some kind of print head cleaning utility. Try that first, if that doesn't work you may want to try new cartridges.You can find some quality, low cost cartridges online since the Canon cartridges don't have a built in print head like Lexmark and HP. Hope that helps.
Posted on Jun 19, 2009
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
How to print on postcard size paper?
Most domestic printers have a variable paper tray in which you can adjust the size manually, simply put the paper to the correct corner and print.
Oct 18, 2012 | Canon Pixma Mg5220 Wireless All-in-one...
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
My mp150 wont let the paper feed into it & the b & c lights are continually flashing any ideas
The ink cartridges are empty.Replace them or press
consistently button for black copy and button for color copy.This will disable the function of the printer to show ink levels and you will continue printing so long as the ink finally over.
Oct 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Aug 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 11, 2009 | Canon Office Equipment & Supplies
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma MP 610 Pixma Printer
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
87 people viewed this question
old marine
old marine
