Question about Kenmore Heating & Cooling
What is the voltage on model number 253.8753101
It is a 1986
My power supply does not give output. please guide me on troubleshooting
does transformer get AC voltage on secondary coils
Does bridging diodes get DC voltage coming out
Does voltage regulator chips have DC voltage coming out
Suggest google tv model with troubleshooting power supply video
do this on you tube www.youtube.com
search {your tv model number} troubleshooting power supply
Nov 01, 2016 | Televison & Video
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
I want EHT number. i lost my t.v EHT number
If by eht you mean high voltage transformer, Google the model number with "parts" to see what is available or contact Philips.
Jul 19, 2013 | Philips Televison & Video
Cook temp not working
follow this steps and test with VOM. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magn
Apr 02, 2013 | Maytag MMV4184A 1000 Watts Microwave Oven
Morphy richards oven is not heating and not cooking anything
please proceed according and fix it. God bless you
Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Mar 01, 2013 | Morphy Richards Microwave Ovens
My 65HM167 keeps blowing the bulb, what do I do now?
The ballast supplies voltage to the lamp to light it up and there must be a problem with it supplying too much voltage and burning the lamp out. Do a google search or ebay or shopjimmy.com for price and availibility with your model number. Or google with the model number followed by the word "ballast".
Jun 20, 2011 | Toshiba Televison & Video
How to set the mechanical timer for Intermatic 600 Watt Low Voltage Transformer?
You can go to intermatic.com once you are on there page do a search for your model number, and from there you can download your instructions. Sorry that I could not given you more detailed instructions but with no model number this was as close as I could get you. Good luck!
Oct 03, 2010 | Intermatic 600 Watt Low Voltage...
Need a part for Model Number 38EYG030 Or Serial
as long as the microfards are the same it can be of larger voltage than the one you have just not smaller voltage.
Jun 04, 2010 | Heating & Cooling
Can you tell me where the fuse is for model number JVM1650
under the outer cover inside the unit in a fuse holder,make sure to discharge the hi-voltage capacitor before replacing or touching the fuse,being its the fuse it very well could be the hi-voltage cap that caused the fuse to blow
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
19 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
